K&N Air filter $50 - Is it worth it?
Old 03-13-2008, 07:09 AM
ancientsanskrit's Avatar
Default RE: K&N Air filter $50 - Is it worth it?
Nope should not. Again, haven't had any extensive look at this engine bay yet, so I'm speculating there's a bad seal somewhere. Either that or valve covers.
Old 03-13-2008, 05:30 PM
BuckMR2's Avatar
Just mod the stock air intake as you wouldnt notice any improvement with a K+N.Have tried K+Ns in many modded cars and they sound nice but I have never noticed any difference as you needmore BHP than just adding a K+N to notice any increase in performance.Try this:-
http://jagmotorproject.blogspot.com/...breathing.html
Old 03-13-2008, 10:13 PM
Oldengineer's Avatar
Could be coming from a PCV valve that's about shot.
Regards:
Oldengineer
Old 03-16-2008, 03:40 PM
JP10501's Avatar
So basically,its a stalemate on whether or not the K&N improves performance.
But I do beleive most say it definitely makes the car sound better (which is better than nothing)
But the real reason I would want to buy a K&N is if it actually helps fuel efficiency. does it?
Old 03-16-2008, 07:51 PM
BuckMR2's Avatar
If the K+N lets more air in then surely you must have more fuel to burn the air???
Old 03-16-2008, 09:31 PM
Dennis's Avatar
ud
No it don't work like that, Air doesn't burn.
The MAFsignals the computer (ECM)how much fuel to inject with the measured amount of air that is being sensed..Grade school science tells you that given more air to a set amount of fuel will increase combustion efficiency..Fuel needs oxygen to burn, not the other way around, more air by volume, more the O2ratioto fuel, hence a more complete burn and less CO,..So, yes the K&N allows for more airflow over the long haul as it allows freer air flow even when dirty, compared to a dirty paper filter, extra air WILL increase mileage as you are getting a morecomplete burn and more bangout ofthe fuel injected.
Old 03-16-2008, 09:43 PM
H20boy's Avatar
Received 1,151 Likes on 753 Posts
If we're just stepping up to support or refute the use of K&N filters, I will state that I believe in their use. I noticed better gas mileage with the Jeep (of course it was coupled with the cold air intake system), and fully believe that it is aiding in my gas mileage with the XK8. Personal preference though...i find it worth it.
  #28
Old 03-17-2008, 06:02 PM
jagxtype's Avatar
Have had mine in for about a week and it seems a little peppier (just quicker to rev while letting the clutch out), runs a bit smoother, and seems to have helped MPG by about 1 mpg. The biggest kick is going to be the ability to clean it vs. the price of the paper filter.
Old 03-17-2008, 07:10 PM
JP10501's Avatar
I was told by my dealer that adding a K&N air filter would void my warranty !?!. I didnt get a clear reason as to why, other than the fact that it is an aftermarket part.
If it voids the warranty, its definitely not worth it.
But if it doesnt, it sounds like a good investment...
I'll take a 1 mpg gain over none.
  #30
Old 03-17-2008, 07:16 PM
jagxtype's Avatar
im outta warranty so i could give a damn less. But it voids warranty with the assumption that the oil from the filter could cause various sensors such as the MAF, MAP, Throttle servo, and other electronics to be contminated and ruined causing negligible damage to the engine. It would never happen unless improperly fitted and maintained, and could just as easily happen with a paper one not installed correctly. Simple as this; out the K&N in your car and keep the old one in your K&N box and if it needs serviced, replace the K&N with the paper one you have saved and no harm done! Put your K&N back in when done with service.
  #31
Old 03-17-2008, 07:17 PM
Dennis's Avatar
ud
Your dealer is full of ****...I've had mine on throughout the entire warranty period and into my extended warranty, without one word of concern from my dealer..
Besides that..the Magnuson-Moss act prevents the dealer from any such BS with aftermarket add ons.
  #32
Old 03-19-2008, 08:21 PM
JP10501's Avatar
Good call on switching the filter out for service visits ...
  #33
Old 03-19-2008, 08:42 PM
Received 9,011 Likes on 4,114 Posts
Size:  6.3 KBName:  X6JYMSAAB5.jpg
Size:  6.1 KBName:  AudiX6JYM-2.jpg
Dennis, I don't know about a filter but certainly most parts that are aftermarket, if fitted can and probably will void any warranty as far as I'm lead to believe.
Jagxtype......great idea of you run with a K+n filter to swap it out before servicing if in warranty.
Jim
  #35
Old 03-19-2008, 10:01 PM
I'm not missing anything Bo............I said exactly that on page 2 I believe it was before I got into it.
Jim
  #36
Old 03-20-2008, 12:07 AM
jagxtype's Avatar
We got it Bo. The thought of being able to wash it and not having to take the trip to the dealer was enough for me. Seems i have been consistantly getting better gas milage though. Was the same way with every other car i installed it on too.
  #37
Old 03-20-2008, 08:52 AM
Dennis's Avatar
ud
And you will continue to get better mileage even when it gets dirty..I can't believe anybody would be so selfish as to keep using PAPER filters, which requires cutting down and using precious trees, which they are in such short supply...Secondly, they act as air purifiers to scrub the atmosphere of CO2 and returns Oxygen back, hence reducing the effects of greenhouse gases...Anybody, who uses paper filters are just mindless and selfish of the environment.
  #38
Old 03-20-2008, 10:11 AM
Lol..........you havin a pop at me Dennis?[&:]
I use paper filters[&:][&:]
I'm gonna rush out and buy K+N to do my bit for the environment right now!!
Seriously though, its gettin that you don't know what to do for the best and whats right / wrong and whats good / bad anymore[].
Jim
  #39
Old 03-20-2008, 11:12 AM
Dennis's Avatar
ud
I was just kidding of course to show the ridiculousness of being an hypocrite and a do gooder leaf lickerat the same time..
No harm intended..
  #40
Old 03-20-2008, 11:38 AM
Cadillac's Avatar
Exactly
[IMG]local://upfiles/1277/058B5EFF83B5448EA0358465D55E0986.jpg[/IMG]
Quick Reply: K&N Air filter $50 - Is it worth it?
