Kenwood KNA-G510 Add-on navigation system
Guest
Posts: n/a
I have a kenwood DDX7019 head unit and I just bought a KNA-G510 Add-on Naviation system. Has anyone installed one of these in a Jag? Or can help with some information on how to install one. Im pretty sure I know how to do it but I have to install three wires on the ignition, the battery, and the parking brake. I dont want to mess anything up. Here is a link the install manual that shows how to wire it.
http://inform3.kenwoodusa.com/manual...10_Install.pdf
Thanks in advance to anyone who can help
Mike
Mike
Good unit, its actually made by Garmin (GVN 53) for kenwood. I have had one installed on my car as well to replace the outdated (and never to have current maps) nav system. It is very easy to install. Audio out to the deck, video output into your deck, power, audio mute lead, and of course the ground. There isn't even a parking brake wire..instead, there is a software setting that allows the 'safety' setting to be turned on or off. (Safety setting being no access to the address typing, etc). If the deck is nav ready, it should be really easy. You may have to switch sources to get from nav screen to say...the DVD source. But, turn by turn audio should still work and interrupt , regardless if it is in the NAV source. g'luck!
Guest
Posts: n/a
thanks h20boyim just unsure were the ignition and the battery wires go the install manual shows themgoing to the car fuse box do i have to splice wires? i get it on monday ups so maybe when i have it in my hands i will figure it out but i never messed with the fuse box before i dont want to mess anything up
Fuse box...they really mean to EITHER the fuse box, or a constant power wire in the car somewhere...if it were an amp though, it would go directly to the battery. The rear of your deck will have the power already connected, just splice...and the remote lead will be on the rear of the deck too...again, splice. It looks like the kenwood unit DOES have a parking brake lead for safety reasons. Just ground it so you don't have to deal with that. (splice to the ground wire on the deck too)
Hey schmidty if I were you I'd run a new wire for the double din and for the navigation from the fuse box if there isn't already one. Most of the time even aftermarket single din normal cd players recommend running a dedicated wire to your radio. The stock wire is pretty thin. I'd imagine that double din has a 15 or 20 amp fuse on the back of the radio. Especially when you consider your radio puts out what 88 watts rms and the stock radio probably doesn't put out more than 20.
How's that kicker set up working for ya? I never got to see any pics or vids???
Guest
Posts: n/a
thanks aquill1 i will try that hopefully they already ran a thicker wire
the kickers sound great but i cant stop the trunk from rattling i put some dynamat in but i ran out i have to buy more the trunk kit does about half the trunk i put two ports in the back it didnt stop the rattling but it made the bass about 100 times louder
![](http://i145.photobucket.com/albums/r222/schmiidty/DSC02779.jpg)
Thats crazy! Man I want to hear it! You might want to think about double coating it with dynamat. Which one did you get original or extreme? How many square feet did you buy? Let me know if you need some more I get deals on it so let me know if I can help ya out. I'll be in michigan from the 10th to 16th so let me know...glad it sounds good! Bet it bumps pretty good with that 550.2 pretty nice amp ain't it? Bet that kicker factory box makes those speakers sound good too...
Guest
Posts: n/a
i got the extreme http://www.onlinecarstereo.com/CarAu...roductID=13389it helped a little but i ran out i have to get more i had a custom box made to fit pushed back in the trunk and they put in the ports the place i had it made promisedme that it would stop the rattle butit didnt so they gave me my money back and but the old box back in now im gonna dynamat the **** out of the trunk but i have the nav thing and im not to sure how to run wires from the fuse box im gonna look at it tonight and see if i can figure it out i got a quote for 700 for a custom box from another place to completly seal of the subs from the trunk and he promised no more rattles so if the dynamat doesnt work i will do that
Seriously don't spend 700 bucks for a box man! It ain't worth it! I can guarantee a pro could put a few layers of dynamat to solve the problem. The other thing you have to figure is that once you seal that trunk off the rest of the car is going to vibrate and make noises elsewhere so there really isn't any getting around it. The dynamat should keep even more bass into the vehicle so I'd imagine that thing sounds a bit louder doesn't it? The other thing some people do is spray foam in cracks and crevices to seal it off and not allow metal to cling. If you want to learn some stuff go to stevemeadedesigns.com and put all your information on there. They have a great wealth of knowledge when it comes to car audio.
42Ajd
12-30-2015 09:45 AM
FS[MidAtlantic]: 1997 XJ6 VDP - Very RARE Black on Black
42Ajd
09-21-2015 07:37 PM
