key fob battery change
RE: key fob battery change
Well, replacing the battery is as simple as finding out the molecular weight of an electron, but reprogramming is the big issue! When you change the battery on the remote, you'll have to reprogram all of your key fobs at the same time! Here is the link! Next time...there is something called searching!
https://www.jaguarforums.com/m_18265/tm.htm
....btw, at least have the decency to come back and let us know if it worked or not!
Received 9,011 Likes
