Key Fob Not Working
Hey I changed my battery on my key and programmed it correctly and it worked for a couple days and then it stopped working now when I lock from the key fob it makes the noise but doors don't lock and also when I open the trunk it opens but my alarm goes off. I have to lock the car with the key and it is annoying. Anyone know of any past issues and I need new buttons since mine are alittle worn out
Daniel.angeles001 (03-28-2017)
Are you sure the problem is the keyfob and not the door locks? Are you saying that when you open the doors with the fob NONE of them unlock or SOME of them unlock? When you use the key in the door to unlock them do NONE of them open or SOME of them open?
You might want to try and move the lock/unlock button on the doors back and forth a number of times to see if you can loosen them up a bit. I remember when I had my X one of the rear doors that I did not use often would not always lock with the fob and if I worked it back and forth a number of times it would be good for a while. Just figured it was from lack of use.
