Key fob remote not working
Driving Jaguar 2008 X-Type 2.0L diesel.
I have used my key fob perfectly ok till yesterday but when I got home my key would not lock my car. I then realised my fob wouldn't do anything, I assumed it was a dead battery so I put a new battery in.
Reset it with ignition but doesn't beep when pressing key even with a new battery so tried my spare key with a nice new battery as well did the ignition pairing of key. But still no beep when pairing key. The car beeps but no second beep when pressing key fob so I know have no remote central locking.
Anybody know how to fix this problem?
Last edited by GGG; 12-15-2018 at 02:50 PM. Reason: Emphasise Model & Year. Add line breaks.
Welcome to the forum Djs210664,
I've moved your question from UK & Eire Region to X-Type forum. This is the place to post technical questions about your model.
These keys are getting old and things go wrong.
1. Dead battery, you replaced that.
2. The buttons are rubber covers that go over very small switches.
These switches are soldered to a circuit board. This solder joint
can break. If you look closely you can see if they are broken.
If you are really adept at soldering you can repair the break.
3. Corrosion. This key fob has had a hard life: the damp dirty
environment in your pocket. If you look at the switches you
might see some green goo on them. If so, then the switch is
probably bad. Some people replace them but you must be
really good at soldering.
4. Bad chip. Hey, even silicon can fail!
I have had some luck with buying used fobs on ebay but your
luck may vary.
luck may vary.
Martyn Musch
07-24-2023 04:01 PM
duanelj
05-05-2014 08:22 AM
