Key fob will not pair
The key fob for my 2001 2.5 Se recently ceased to work. I replaced the battery's in both fobs ( the reserve fob having failed some time ago) I then followed the programming procedure but failed to get a 'bleep' after tuning the ignition key the stated 4 times between 1 and 2 ?
Any suggestions .
Any suggestions .
Fobs sometimes fail because of the switches. There are two things that often happen in older fobs. The first is that the switches break their solder joints to the circuit board. There are 4 solder connections on each switch. Sometimes only one breaks and and it looks OK unless you use a microscope. Sometimes all 4 break and the switch falls out of position. I have heard of people re-doing the solder.
The other problem is corrosion which appears as green gunk around the switch. I don't know if this can be fixed.
Pete.
Pete.
Most on the UK Forum use fingazfobz
" If, for any reason the fob is not repairable, you will receive a FULL refund of the purchase price, MINUS the cost of return shipping to send your fob back "
fingazfobz | Fob Repair Service
The following 2 users liked this post by iownme:
DaveJessop (03-01-2017),
JWRussell (03-05-2017)
