Key Transmitter
Old 10-25-2006, 09:30 PM
X2 Jag's Avatar
Default Key Transmitter
Hey guys...im new to the Jag scene so im trying to get familiar with my 02 X Type. I bought the car off a good buddy. He only had one Key transmitter....the buttons dont work so im wondering if the battery is dead...how do you open it to check? 2nd.....I found a new Key transmitter with a uncut key on sale on....it mentions the FCCID, CAN and part number....how do I know if its compatible with my Jag?
Old 10-25-2006, 10:17 PM
racerx82's Avatar
Default RE: Key Transmitter
Congrats and welcome
Never had to replace the battery in mine yet, but it does look tough.....can't help you there...as for programming your FOB, it should work when you follow the procedure for activating the FOBs (providing the battery is good in that one as well)
________
PREGNANT ****
Old 10-25-2006, 10:42 PM
X2 Jag's Avatar
Thanks man....Does the user manual show how to program it? If so...ill need to purchase that manual since its not in the car. [>:] I guess the transmitters use different frequency channels so you have to check first to see if it works with your car.
Old 10-26-2006, 12:49 AM
X2 Jag's Avatar
Ha nah i wont slap him...he's a cool guy.....Ill see if I can find one on ebay.
Old 10-26-2006, 01:45 PM
BuckMR2's Avatar
Default RE: Id still tell my buddy why to keep manuals
The owners manual is online here:-
Owners Manual
Go to section 2-4 for how to replace battery
Old 10-26-2006, 04:32 PM
X2 Jag's Avatar
ORIGINAL: BuckMR2
Owners Manual
Thanks!
Old 10-26-2006, 08:19 PM
racerx82's Avatar
cycle the ignition key three times, leaving it in the run position (car not running) press door lock button on transmitter 1, than on transmitter two.
That should do it.
________
CHEAP S THUNDER POWDER SPRAYING LANDMINE ACC PL03
Old 10-27-2006, 01:34 AM
X2 Jag's Avatar
ORIGINAL: racerx82
That should do it.
Now this procedure will do what?
Old 10-28-2006, 12:45 PM
racerx82's Avatar
Starts the Auto destruct sequance
________
Launch Box Vaporizer
Old 11-01-2006, 09:03 PM
racerx82's Avatar
Programs the key FOBs
________
Website Host
Old 11-01-2006, 09:11 PM
X2 Jag's Avatar
What is the purpose of the FCC ID? Seems that depending on the ID or the remote...it might or might not work on your vehicle right?
Old 11-01-2006, 10:37 PM
racerx82's Avatar
the FCC is the frequency code (I believe) and yes, it may or may not work.....i'm not sure how to go about purchasing the correct coded key...
________
Cam Sex
Old 11-02-2006, 06:11 AM
X2 Jag's Avatar
ORIGINAL: baztroy
I've experienced a similar problem (key transmitter not working) with my 2004.5MY X type (yes there was a mid year facelift and interior trim change). I am informed that in October 2006 a service fix was released. Apparently the key transmitters suffer from static build up which affects the circuit board - so it won't work even with a new battery. The fix is to put a sliver of special (presumably conductive) material into the transmitter, which prevents this. My local dealer is doing that as I write under warranty. So I recommend that you go to your dealer and get it fixed for free.
Interesting.....i replaced the battery on my transmitter and it still didn't work...this makes sense....My car is not on warranty since it past the 51K mark...so I dont think the dealer would fix it for free. [>:]
Old 11-03-2006, 10:18 PM
So when they use the term "lock barrel"! They mean the ignition. Squirt some WD40 in the ingnition and work it with the key? Is that correct?
Quick Reply: Key Transmitter
