Leaking Coolant around the By pass Pipe
I have a 2004 X-Type with a 3.0 motor. On the right side were the by pass pipe goes into the heads there is a small amount of coolant laying between the heads. The leak is quite small. I think I need to replace the gaskets that are on the by pass tube. I need to know if I can remove the by pass tube from the heads with out removing the intake manifold and the injector system? Any help would be great.
Thanks Hawgdog
Thanks Hawgdog
aholbro1
08-05-2021 05:02 AM
