Leaking hoses in the cold
So I was driving home the other day and got stopped at a red light. I had the heat on 84 and noticed the car was blowing out cold air and not running up to par. I continue driving and I realize steam coming out of the engine, so i pulled over. It turns out, what i thought was a leaky hose, was really the piece that sticks out into the hose, and it was cracked. what do i do? Can this be fixed diy? Or should i take it to the dealership. The car is just parked outside my house, i kinda ghetto rigged it so where it doesnt leak anymore but i dont feel safe driving it.
Cean B.
[IMG]local://upfiles/3797/B7FDDD83184D4E26AF954181AB228BE4.jpg[/IMG]
[IMG]local://upfiles/3797/F504B47C9D65423B94C0961B79485A7F.jpg[/IMG]
[IMG]local://upfiles/3797/79FBD074365941259C6BCD27FED0A6F2.jpg[/IMG]
Cean B.
Received 2,192 Likes
This place here..you should get a new cap too..don't forget to use only distilled water with 50/50 with the Jag coolant..
http://www.trademotion.com/partlocat...layCatalogid=0
WHATS NOT TO TRUST ABOUT REPLACING THE RESERVOIR? BUT THEN AGAIN YOU COULD SLIP A SMALLER PLASTIC FITTING INSIDE AND EPOXY IT ALL TOGETHER WITH SOME GOOD PLASTIC EPOXY. THE ADDED PIECE INSIDE WILL ADD STRENGTH. i KNOW XTYPE OWNERS ARE ALWAYS TRYING TO SAVE MONEY
This is something else I've had to do to my car in the past couple of months. Mine developed a hair line crack on the bottom of the tank, which when hot, will expand and cause a major leak. I would strongly advise against trying to repair the plastic tank (even with a high quality epoxy), due to the constant expansion and contraction the tank goes through.
The tank is not a dealer only item. Many Jaguar parts suppliers have these. I bought mine from Welsh for $130. Install time was less than 5 minutes.
clubairth1
29
05-10-2024 12:57 PM
aholbro1
08-05-2021 05:02 AM
OkieTim
09-08-2015 04:48 PM
