leaking oil pan gasket
Went in planning on drilling the transfer case as others have done. Found one bolt on the pan a little loose, took a chance and tightened it. So far, so good, a tank of gas later and it's not leaking.
Was a really small leak so I'm hoping I get lucky.
Wonder how hard it would be to replace the gasket the right way?
Received 3,892 Likes
Boz, from what people have said, plan on taking about 10 hours or so. There is a lot of collateral stuff that needs to come off in order to access the bolts for the oil pan. I would say that as long as you are not leaking, call it good enough. Sounds like you got lucky and simply had a bolt to come loose. Smile and move on.
Really hoping this simpler fix works because that was a LOT of work :-)
aholbro1
08-05-2021 05:02 AM
