This legit?
found another product
http://cgi.ebay.com/ebaymotors/Parts-Accessories___Jaguar-X-S-XK8-XKR-Type-Gas-Saving-Fuel-Saver_W0QQitemZ150306307084QQddnZPartsQ20Q26Q20Acc essoriesQQddiZ2811QQcmdZViewItem?hash=item15030630 7084&_trkparms=72%3A543|39%3A1|65%3A12|240%3A1 318&_trksid=p4506.c0.m245
Received 3,894 Likes
As the other guys pointed out, if these were as good as stated, don't you think Jag would have put these into the cars already?
As for the tornado piece (second one you listed), that is actually a part that would work if located in the correct spot. But, putting it upstream of the throttlebody kills all the effectiveness of the part (if anything, adds more restriction, therefore would reduce power). You would need to install a few of these (6 to be precise). You would need to install these at the inlet of the intake valves. That would then spin the air as it entered the cylinder, leading to better fuel mixing with the air, therefore more efficient burn. As for the computer plug in piece, it might work if you drive a particular way. But, odds are, you won't want to drive how that box would want you to. So, save your money. If you have to spend you money, there are other things that you can do to the motor to make it more efficient.
