lift kit for Jaguars
Guest
Posts: n/a
You can spend a few bucks on some performance shocks and simple brackets to completely change your Jaguar's height and look. You can also opt to ditch the stock springs and shocks altogether for a set of adjustable air bags. Though some people install a suspension lift for aesthetic purpose, others purchase it for its principal purpose-- to lessen the jarring of the automobile that is caused by irregularities in the roads traveled. Since the wheels of an automobile accelerate, stop, and steer it, the suspension lift kit must also serve to keep the wheels in close contact with the road surface at all times. Suspension lifts (also referred to as lift kits or leveling kits) enable steeper ascent, descent and breakover angles, higher ground clearance, and helps accommodate larger rims and tires.
Whether you wanna lift your rig for a cool look, better performance or towing big loads, the market has every option covered. It is just up to you to choose a trusted online lift kit shop or you can try at Amazon, Suspension Lift Kit.Net, Ebay, or other renowned online sources for the perfect product for your beloved vehicle.
RE: lift kit for Jaguars
ORIGINAL: mcqueen
You can spend a few bucks on some performance shocks and simple brackets to completely change your Jaguar's height and look. You can also opt to ditch the stock springs and shocks altogether for a set of adjustable air bags. Though some people install a suspension lift for aesthetic purpose, others purchase it for its principal purpose-- to lessen the jarring of the automobile that is caused by irregularities in the roads traveled. Since the wheels in close contact with the road surface at all times. Suspension lifts (also referred to as lift kits or leveling kits) enable steeper ascent, descent and breakover angles, higher ground clearance, and helps accommodate larger rims and tires.
Very old and very stupid trick. Throw some "general" websites in to make it look less intrusive, then throw YOUR website in the middle to try and hide it with the others around it. That's why his other posts have links in them. He's a website traffic driver.
Die you worthless *******.
1964Daimler
08-31-2015 06:37 AM
Vector
US Lower Atlantic
08-26-2015 05:36 AM
