List of fault codes
Gentlemen the codes I'm getting back are these B1f00
P009F
C1145 front right abs sensor
U3641
C2b10
P009f
U3600 EGR system fail
P00f6 Air intake humidity sensor
Ive not been able to find some of them anywhere.
Thanks to Dell the link still didn't pull anything up, beginning to think I might have a faulty ECU
P009F
U3641
C2b10
P009f
Received 3,932 Likes
Hex, from what I am seeing, your problem is either stemming from a bad MAF sensor or you have a leak in the intake between the turbo and the cylinder heads. With that being said, C1145 has nothing to do with your overall problem. That is a separate issue and should not be considered when looking at the engine performance problem. So, I would say a smoke check of the intake would be the first wise move and then start looking at the MAF and is associated wiring.
I'm going to strip the inlet manifold and EGR valve down and clean it all up as a start, Ive been trying to see if theres any wiring issues I can see around the sensors, I did replace the MAF with a new Lucas one about 5 years ago, so an inspection / clean I hope will suffice. I have noticed some of the pipes around the turbo have thrown some gas / oil over the surrounding parts so a replacement of these will probably also be undertaken as standard practice.
Its a process of illimitation Im afraid to throw new parts at it rather than put into a shop, will cost less in the long run.
The C1145 was from the hub I was working on earlier this year and will be checking shortly while replacing a failed strut top mount anyway.
mesaboogieman
01-28-2020 01:03 AM
