Little, 'free' simple Mods..Anyone else do these?
Anyone else do the following to their X-Type:
-Throttle-body coolant bypass
-Air Intake resonator delete
-Exhaust resonator delete
-Remove heat-absorbing foam from under the intake manifold (it's put there to decrease horsepower and decrease emissions when coming to the states for certain ratings)
The coolant recirculation is a REDUNDANT design that gathers heat and restricts horsepower by recycling the heated coolant to the throttle body. Some may argue this was installed to prevent icing in the winter.... I've done this to EVERY car I've owned for YEARS, and even this winter, my X-Type started in one turn on a morning it was -16 Fahrenheit sitting outside my hotel all night.
The air intake resonator-delete is REALLY easy: pull it off, and stick a rubber grommet in side, then melt the grommet to the inlet if you wish to fuse them. I also duct taped it after inserting just for insurance. JUST MAKE SURE THE GROMMET IS TAPERED! you don't want it sucked into the engine!
On a V6, the gains aren't as big as I've seen on V8's, but that is always the case. Diminutive gains and a little pep is about all that's added with these, but again, they are FREE.
Another mod that may have to do with the engine's 'timing' is one step colder spark plugs. I've done this to both X-Types to get rid of sluggish response, and it has worked on both of my X-Types.
Google the coolant bypass mod, it looks pretty much the same on any car. I'm sure the Mazda6 guys have figured out, or the Ford Contours.
That intake did free up some quality gains, but no one responded to our production of it, so I sold it to someone whom I've yet to come across on these forums.... lol
Personaly i would think that a team of English engineers know how, and what to put into a car to make it would better then this lil-ol'-Colombian-kid. But as i see all you guys talk about this I question my previous stance on the matter.
I guess that when said team is designing the car they have to make it work on a very broad spectrum. So if you know your car is in the dirty south (southern USA) you wouldnt need all that anti-freezeing equipment.
So my question is, is this really worth it? To make changes to your ride that could effect longevity? Because allthought you may think that a hose only effects the coolent system you might inencertantly effect other parts of the car. Im not trying to sound like a smart ***. I honestly dont know enough to answer that.
All of the necessary functions to operate are still occurring, and in fact, these particular modifications allow the car to perform 'better' than intended.
A large floormat might 'come from the factory,' but it's still a good idea to swap it out or modify it if it's causing the gas pedal to stick or blocking the brakes.
Not really even anything worth arguing over.
As a pilot I learned that carb ice was more of a concern on a summer day with high humidity. A carbs venturi will ice up in mid summer. Activating carb-heat (diverting manifold heat near the carb) was performed at mid field downwind so if a chunk of ice decided to melt off you could dead stick a landing. Been there, done that. Engine failures at 1000' suck. Car stalls on street, no big deal.
That being said, I don't know anyone who ever stalled their car using the coolant bypass mod. Some cars benefit from it, some don't. My guess is the X is in the latter group. And exactly how many people are taking their X down the 1/4 mile to "reap" the benefit?
The stock setup has NO effect when starting a cold car because the coolant is also cold. As the coolant warms it provides the TB with heat to thaw any ice that forms. You'd have to ask an engineer exactly what conditions are needed to freeze a throttle body but keep in mind what the wind chill might be when dealing with a venturi.
...All good points. Well said.
Received 3,887 Likes
Huh, my idea of free/cheap mods is a little bit different. Having an air brush at my disposal, I do a lot of painting upgrades for dirt cheap (cost of a quart of paint is pretty low). I did a Sport conversion on my car for less than $100. I am now in the process of converting the outside lights to LED which is only costing me about $1 a light. But then, having a little bit of wiring knowledge helps with that.
The next projects in store for my car is probably going to be a repaint of the defroster vents to blend with the dash (mine are currently a light brown where the dash is a much darker brown) and then probably an "expansion" of the wood trim on the doors to encompass the entire void on the side. I think that would look interesting. I just have to find an exotic wood place near me to get some of the burreled wood. Granted, if I can find some, then I might take the time to redo the dash vents too. Help tie the dash together a bit more. That would be mainly time, not so much cost. All the ideas.
I would be interested in doing the TB coolant delete, Mr Bond, what is it you need to do? Is it just blocking the coolant pipes?
Hi- could you explain a little more about, "the foam under the intake manifold which you will need to seat new gaskets underneath"? I still have the foam and am going to do the upper and lower intake gaskets, for the first time, this weekend and would like to remove the foam if not needed, but am not sure what you mean?
