Locating a fuse without pulling out all of them.
Before I pull out all the fuses in order to just find which one links to the "brown and white" wire that (I believe|) will power my new stereo, I thought i'd ask here incase anyone knows which one it is?
My car is a Jaguar 2004 X type sedan. The brown and white wire from my understanding "should" be lighting up in my circuit tester? But it doesn't. Any ideas??
_____________________
2004 X-Type sedan 3.0 L
Welcome to the forum ArnoldsJAG,
I've moved your question from General Tech Help to X-Type forum. This is the place to pos technical questions about your model.
Received 3,932 Likes
Arnolds, you have 2 options when it comes to the fuse that you are looking for. I say this because in 2004, some of the vehicles got 1 wiring harness (ie, before the upgrade) and others got a new and improved harness. What you will need to do is look in the driver's door jam and see when your car was built. Was it on/before March 2004 or after.
As for the fuse that you are after, here are your two options:
The early cars it will be fuse F72 in the cabin fuse box. This will be a 15 amp fuse.
The later cars it will be fuse F44 in the cabin fuse box. This will be a 15 amp fuse.
ArnoldsJAG (02-12-2019)
S2005
11-14-2018 02:51 PM
fonewiz
05-06-2011 03:24 AM
viscoussquirrel
General Tech Help
01-09-2010 12:55 PM
wnlewis
XJ40 ( XJ81 )
02-09-2009 10:47 PM
