locked glovebox
If you haven't used it much, put a squirt of oil on the lock, and let it sit for a couple of minutes. Then try moving it back and forth about 15 times. Also try holding it closed while doing that. If it is still stuck try GENTLY!! tapping on the key, with it in the lock. That is about all I have for you. You use the same methods for outsice locks, and house locks......Good Luck....Mike
RonnieJoe (06-22-2015)
philwarner
28
07-11-2017 10:21 AM
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
