long awaited pics..
long awaited pics..
if youve read the oil pan gasket change thread in the faq section, i have some pictures i found. theres about 12 or 15 but ill put up the good ones.
from left to right,
pics 1-3, camera facing same as driver would, but looking up from underneath car, pan on
4+5 camera facing rear of car, oil pan off, tc mount side view after drilling
1-messy oil pan in the beginning. this is a shot of the tc with the back corner of the oil pan, at left in photo is oil pan bolted to tranny
2-a shot of the two lower mounts of the tc, the lower one in photo is the one blocking the hidden bolt
3-hole is drilled. i did not punch through the inner wall of the tc buts lets just say i wouldnt have gone any farther towards where the oil is. after removing the shavings i stuck a socket right thru the hole and removed the bolt carefully, it was pretty tight as i was a hare off and not perfectly in-line, but darn close. a little more right from this angle wouldve been ideal
4-side view of tc mount drilled, oil pan removed, note placement of hole in mount
5-same as 4 but this one shows it all. a tad to the left from this angle
there it is, long overdue. have some more pics if anyone needs -stevis05
from left to right,
oil pan gasket removal
hey stevis05, could you please send me the pics from start to finish, was it real hard, and did you have to remove a lot from underneath??
rteabrok
rteabrok@cfl.rr.com
rteabrok
rteabrok@cfl.rr.com
Wolfy
05-28-2024 08:06 AM
Jaguar Forums Editor
Jaguar Press release
09-15-2015 12:48 PM
