Looking for Tranny Advice
I have an 04 x-type 3.0 that suddenly started with tranny issues. I was rolling to stop at a light when it turned green and got back on the throttle, the tranny kicked hard into gear and during the next updshift seemed to slip , took longer to get to the next gear. I would supoose this was 1-2 or 2-3. I was right outside my offcie at the time so i parked it for the rest of the day. On the commute home i did not experience any issues (25 miles) but i didnt accelerate hard either. Later that night i tested it again and it did the same from 1st to 2nd, very hard shift with what seemed like a slip between upshift. I have 56K on it and i didnt purcahse any addnl coverage. Any advice on whether to take this to an AAMCO or the dealer? I'm in Long Island New York and would appreciate any advice.
Lean bank codes. Most likely a vac leak, at least that's where I'd suggest you start. Have a look at your PCV hose running from the intake to the valve cover next to the airbox. Look for splits or cracks. If your hose is smooth, a newer ribbed version is available. Could also be a leak from the IMT o rings (search the board, plenty of info on that one). Also brake booster vac line check valve is another thing to check.
Have a look at those and report back....
Vac Leak
thanks chris, turns out the check valve between the manifold and brake booster was cracked & leaking. expalins dtc 171 and 174. Ill replace this weekend but i cant imagine how this would cause the bucking thats coming from this tranny, but i've been surprised before. fingers crossed.
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
