looking for a write up on clutch replacement.
i have a 2002 x type sport 3.0 5spd. I want to replace my clutch, pressure plate, slave and flywheel with the 2005 revised clutch c2s49289 and I'm looking for info. I need to know which flywheel and slave are compatible and any other parts needed, bolts etc. I'll be sure to do a write up if one doesn't exist. any info about the swap would be appreciated, thanks.
here is my write up. do not try to replace the clutch on this car without dropping the engine, trans, and t case together as the jtis is 1900 pages of lies. leave yourself more than 10 days to do so. and if you buy the newer 2005 clutch find out if the splines match up, as I still do not know.
on a side note i just drove it 2100 miles between 85 and 115 mph and it was awesome and didn't burn a drop of oil. good car, but clutch replacement sucks big time.
also only use impact on rear subframe bolts because the captive nut in body will break welds and spin.
