loosing coolant/antirfreeze
2002 x Type, 111k miles, 2.5l. Loosing coolant about 32 oz in 200 miles. Check under car-no coolant. There is no white smoke from exhaust and no milky oil. I purchased a coolant combustion tester to determine if their was any combustion byproducts in coolant and it tested negative which indicates that the head gasket is good. Any ideas what is going on?
Howard
Howard
Received 3,909 Likes
hak, I would say to get yourself a coolant system pressure tester (can be rented for free from most auto parts stores). Fill up your expansion tank and press the system up to 15 psig. If you have a black light, this will be beneficial (most new coolants have a build in UV die that will glow when lit with a black light). You can then look around the engine bay with the engine off and the system at pressure. Like was said, you are likely to spot a leak at either the T-pipe near the radiator, the vent line from the motor to the top/back of the expansion bottle, or out the front of the water pump. Shining a black light into the engine bay (especially when it is starting to get dark) will cause where the coolant is leaking to glow. You can then trace the trail back to your source.
Howard
Howard
hak, honestly, I would not worry about reattaching the foam. If the radiator is leaking, it is only time before other parts of it start leaking. So, I would be looking for a new radiator and that should have the new foam already attached. if not, then I would say to look for something like Gorilla glue or the like that comes in a big bottle. Run a strip down the side of the radiator and attach your foam, pressing it in place for the first 5 minutes or so. By then ,the glue should be set up enough that you won't have to worry about it.
newjagowner
10-05-2012 04:44 PM
Alwann
09-23-2009 03:18 PM
