loud grinding noise when lifting clutch to engage gear
Hello i'm having an issue with my X type
When it first occurred the clutch pedal stuck to the floor and I had to pull it back up with my foot.
Pedal is fine now
All gears engage fine with the engine off
Once engine is running gearbox still goes into gear no problem
But when you release the clutch to start moving it makes a loud whining grinding noise, judders slightly then pulls off
Then this repeats with every ear change but noise is reduced a lot after first.
Brake fluid level is normal, I understand clutch shares this fluid?
Anyone have any idea? hoping its not the clutch itself.
Thanks in advance guys
Jay
Pedal is fine now
Jay
