loud radiator fans
Received 3,915 Likes
konshu, from what you are describing, I would first check to see that all the blades on the fans are in place. Even a small nick in a blade can cause it to be unbalanced, leading to excessive noise. Granted, if the fans simply kick on to full speed any time the fans are needed, then odds are you are looking at a fan module that is starting to go.
Problem could be the control module is receiving a hot engine condition and is running the fans at max speed. These things sound like a B29 at take off when running on high.
baskervillema
10-01-2015 06:43 PM
