low brake fluid level warning, but the fluid level is good~~ WHAT IS GOING ON?
I recently got a low brake fluid warning on my onboard screen of a 2003 X-Type 3.0L. just bled all brakes and topped off my brake fluid~ low fluid warning still there. i unplugged the fluid level sensor, and the warning is still there. Do I need to replace the instrument gauge? Anything will help~~ thank you!!!!
is that right? i've read different opinions in regards to that, but want to check it now~~ what is the easiest way to check it? without buying a new one~~
Sure... get a paper clip (metal paper clip of course).
Disconnect the sensor
With the paper clip touch the connector ends and have a buddy see if the light goes out.
If it does then you have a sensor problem. That's how I test them at my shop... no need to get big guns out (multimeter).
Best of luck! and let us know the happy ending!
You can plug a good spade fuse into the plug, which is a better way to jump over because it won’t short out and stays in place. In my case it didn’t tell me anything because it’s just 1 of Jaguars gremlins running around switching warning lights on periodically for no reason whatsoever. It comes on after about 20 minutes goes out comes on again maybe.
Michael_Yarnell1
02-05-2017 09:16 AM
