Lower Mesh grill
It is factory.. It was installed the right way. I have that same gap on the top drivers side. Hey, RedJag is your clips on the top of the grill toward the center or toward the outside of the grill? I am starting to think maybe the grill is on upside down. Think that maybe it???
Received 9,007 Likes
Pulled mine off again today and put it back on per the instructions...I had done it right the first time, it only goes on one way. Now it has about a 1/4" gap all the way across the top....more uniform anyway...still looks good. Since I'm using the black one,I will likely slit some black tubingand run it across the top.
I just purchased the lower mesh grille from JaguarXP and it looks like a pretty simple install. Are there any FAQ's on installing it? I have a 2002 X-Type and the only thing I'm concerned with is removing the diffuser. Do I need to drill or cut some pieces? Hopefully, its just the basic removing some screws.
Any advice?
Any advice?
You have two options in regards to the lower grille assembly.
The first is to take off the front bumper cover and do it properly (I'm not sure if JaguarXP's install instructions detail this procedure).
Or the second option is to try and assemble with the bumper cover on and be disappointed with the results. If you ever see any pictures where someones lower grille looks totally jacked up or skewed out of proportion it's because they attempted the install without removing the bumper cover.
Here's mine. OEM lower grill (not from jag XP) unless I'm bending down looking at it you can't see the gap across the top. BTW the factory lower grill does not require removal of the bumper cover which is nice.
[IMG]local://upfiles/2846/221EEA0541A444C09C75A1B635F49208.jpg[/IMG]
