Lower radiator hose
THANG is correct you will need to raise and block the car and then remove the underside splash shield. It is held in place with a row of fasteners around the perimeter and and 2 fasteners on each side accessed from the wheel arch liners. The lower radiator hose is actually 2 hoses, a short ( 4inch ) from the thermostat housing to a metal pipe and the a longer one from the metal pipe to the radiator. The drain is a plastic fitting on the right side bottom of the radiator. It can be removed with a large screwdriver or a hex socket.
