lower radiator hose/coolant loss
Hi everyone. I just got underneath my car today and noticed I had coolant leaking right above my thermostat. Im pretty sure my only option is changing the upper radiator hose. But on my car I have this metal pipe right below the thermostat that is also leaking from rubbing against the frame. Is this the lower radiator hose? I've looked everywhere online but I can only find pictures of a rubber hose. Thank you
PS. I would post a pic but I don't know how to do it through my phone
I def saw that I have two leaks....one is right above where the thermostat connects. I would say its some sorta housing that connects to the block. The other leak is this steel hose that connects right under the thermostat. I just don't know what its called. Right now I wrapped electrical tape around it but have yet to drive my car so I don't know how long this temp fix will last
You can call these guys up to see what the part is called as I am not sure either what the name would be of it
New and Used Jaguar Parts for XJ6, XJS, XJ8, XK8, S-TYPE and X-TYPE
1964Daimler
09-09-2015 11:28 AM
