Lug nuts
I am having trouble taking off this lug nut, it just spins around and around its like 90% off and it wiggles but it just doesn't come off!!!&&@$"%#^
I tried pulling on it with plyers, I sprayed WD40 my fourway lug wrench spins around and around I tried banging it off but nothing. Has anyone had this problem with these stupid crappy capped lug nuts?
Received 6,307 Likes
Well I took it to the shop today and they found that the post had broken free of the rivets that were holding the post in place so it was just spinning and spjnnjng. So they welded the back (inside) of the post that kept on moving and that solved the problem so if anyone runs into this problem just have them or of you have a welding torch just weld the back to the hub and it should be fine.
