Lugnuts
Received 3,898 Likes
Ronnie, the caps are not supposed to come off. They are supposed to be form fitting enough to allow a little bit of wiggle, but not much. if you find that they are getting too loose, you would have to probably use a dremel tool to get a slight rip in the covering so you can start peeling the cover off. Not sure if you can slide say a thin blade screw driver on the underside of the lug nut to work the cover off that way.
RonnieJoe (06-12-2015)
These ones fit, and are SOLID!!! should be able to get them over your side!!
16 x TOYOTA ORIGINAL CHROME ALLOY WHEEL NUTS M12X1.5 LUG BOLTS | eBay
The caps come off easy enough.
I had to remove them so the lugs would fit into my Dvinci rims.
That lil bit of metal gone gave me just enough wiggle so they fit.
Do not recall my exact removal process, but it was caveman for sure, no power tools.
RonnieJoe (06-13-2015)
