Maf sensor wiring
Maf sensor wiring
Hi Folks - new to the forum as just purchased my used X type 2.0d 2004. Lovely ride but engine management light with P1000 code down to maf sensor. The 4 wires that are going into it were a bit frayed so after putting new connectors on it and replacing the sensor still got the problem. My question is are the wires in the right order and if they are not would engine still run? going from nearest to front of car there are 4 wires : red, brown & purple, white & purple and brown and purple. Wires might be faded but this was the order they came with. Previous owner was convinced it was the Maf sensor but having replaced and looked at it don't think this was the issue. Help!
Wait! P1000 is not about any one sensor. It is a non-serious status (not error) code meaning at least one OBD monitor has not run OK (aka "set").
More info on JagRepair.com - Jaguar Repair Information Resource but leave that MAF alone (for now, unless it is actually bad).
The following 2 users liked this post by JagV8:
motorcarman (05-24-2018),
SMIFFY69 (05-24-2018)
Thanks Dell Gailey- But where is the red one? Lol. But by the look of the photo I might have a wire out of order. Back to my original question will sensor run if wires not in right order? Will clean egr over the weekend to rule that out and getting garage to do electrical test on wires today along with a tracking issue so just ruling out things as we go along.
An update guys. I need new glasses! It wasn't P1000 but P0100 code. I've since tried to clean EGR valve and still no success. Engine light came on straigh away. After googling every possibility I'm thinking it is probably the wiring loom or the connections and at worse fuel filter? It's running rough and fuel mpg is on a par with petrol at the moment. Any further thoughts? Thanks in advance. Be nice - I'm an amateur!
JimC64
03-02-2015 08:07 PM
