main beam adjustment
Hi normp, you might want to check out the FAQ in the X-Type forum. In particular, there's a list of posts about headlights, or you can search the X-Type forum.
It could be that you simply need to re-aim your headlights, but more likely you have a broken support post, common on the X-Type. Both conditions are covered thoroughly in the X-Type forum.
Hope that helps!
Hope that helps!
Hope that helps!
Hope that helps!
2004, adjust, adjustment, aim, ajust, beam, headlight, headlights, jag, jaguar, main, mainbeamsupportpost, reaim, type, xtype
