Manual fan switch trouble
Mmm. Sounds like you might be trying to cure a symptom rather than the cause?
The cooling fan module is controlled by a PWM signal from the ECM, not a simple 12v On/Off. (Fans are variable speed)
The alternative of splicing in directly into the main fan wiring would require a relay to handle the currents involved, plus some substantial diodes probably to prevent putting unwanted voltage back to the fan module.
flynnaaron
05-04-2024 07:14 PM
weisberg
05-13-2014 10:12 PM
