Manual transmission - no gears
Old 05-01-2014, 11:25 AM
knoxrandall's Avatar
Originally Posted by knoxrandall
I have a 2004 Jaguar X-Type 2.5
I was driving a little aggressively and my transmission stopped working for lack of a better word. Its a manual transmission. In every gear the car doesnt seem to be in gear. Like its in neutral. Even reverse. The motor starts and runs fine just the transmission isnt pulling or engaging. I wasnt able to get the JTIM or whatever its called to work on my computer. I think i could do the repair myself if i had the instructions on removal of the transmission. Any thoughts on what i might have done? Any help with that or the removal process would be appreciated.
So i had my Jag towed to a shop anyway and they said it wasn't the clutch, pressure plate or throw-out bearing.. it is in the transfer case. does anyone know if or how they could know that? also i am thinking if that is correct, i will def try to replace it myself. i am having trouble finding a price on a new or rebuilt or just a used TC. Can anyone help with either problem? Thanks
Old 05-02-2014, 06:36 AM
There are threads on here about replacing a faulty transfer case but it is not a job for the faint hearted, and is not cheap - so it depends on the value of your car, and the cost and time to do this..
Old 05-02-2014, 10:06 AM
ltmax's Avatar
I dropped the transfer case on my automatic last month, took about 4 hours and the manual trans should take about the same time. Send me a pm and I'll send you the Jaguar TSB that explains how to do it.
Used transfer cases are on E-bay for around $600.
knoxrandall (05-02-2014)
tomsjag
06-10-2023 10:02 AM
Jandreu
06-30-2022 03:10 PM
aholbro1
08-05-2021 05:02 AM
lovemyjag78
09-14-2015 07:42 PM
AtholC
09-09-2015 09:07 PM
Quick Reply: Manual transmission - no gears
