Maz is your guinea pig
I had one of those tornado knockoffs laying around and figured, what the hell? My dad bought it a long time ago and never used it. So I figured I'd give it a shot seeing as there's people who think it's great, and those who think it's garbage. I'm pretty sure I know the answer, but I'm trying it anyway.
2005 3.0 auto Sport, paper intake filter, 93oct, 18 mpg average. We'll see what we get after these 5 gallons.
Received 3,898 Likes
jvegas, if you drive easy in the car, you may actually having the car shift too soon and it is never getting into the power band/efficiency band. BY leaving the sport mode on all the time, you are telling the car you want the shift points raised, therefore pulling you into the power band. As a general rule, I have found that most vehicles get their best mileage by looking at where the redline is for the motor and then depressing the gas pedal hard enough that as the engine reaches 50% of the redline, the tranny shifts (never moving your foot). So, with our cars, that would mean that you will want to have the tranny shift at just above 3,000 RPM. Try it for a bit. You might be surprised with the results.
Along this same lines, have any of you played with the intake/throttle body and cleaned up the rough edges to allow the air to flow easier through these parts? I know that most of the gain is going to be under wide open throttle, but if some gain can be had under even partial throttle, I'm game. I have all the tools to polish the inside of the intake. Kinda curious. Granted, if I can get a few extra ponies at WOT for the "fun times", then all that much better. I did this on my truck and it seemed to help some. Even managed to help with some of the low end too.
As for the tornado piece, I don't see it gaining you anything. the whole concept behind the piece is that it spins the air forcing it to mix with the gas more. That is all fine and dandy if you have a straight tube between where the tornado piece is and the cylinder. But, look at how many bends the intake makes between the throttle body and the motor. For every bend of 90 degrees, you loose like 80% of the spinning action. Guys with Ford trucks have actually dyno'ed their trucks with these pieces in and they actually lost power as measured by the dyno. It wasn't a large loss, but it actually hindered, not helped.
Chris "Thermo" Coleman and Nukie, the radioactive 97 X
Maz, you may want to go with 40 psi in the fronts, 35 in the rear. The X-type carries more weight on the front tires than it does on the rears unless you are carrying a full car of people. But, if it is just you, the fronts need to be at a higher pressure than the rears. I run 40 psi in all of my tires.
