melted headlight into socket
I know I know I'm sure it has been answered but only.partially to me I have not found an answer I'm pleased with. I'm sorry to everyone who.is getting annoyed with this question . My headlight melted into the socket and of course the dealer wants.to sell you everything that has to do with a headlight when you tell them the issue. So I wanted to ask the very knowledgeable forums opinion. My plan was to take this harness http://www.racinglab.com/kyo-pnp-wh-h1.html and cut the back off and hardwire it into the original socket after cutting the melted socket off. Follow that by soldering and heatshrinking the wire to look proffessional. Any opioms any one?
Received 3,894 Likes
mrfixon88, stop by your local auto parts store. They should have a generic H1 bulb plug for you to buy. Probably cost you $5 per plug (much less normally). From there, do like you are saying and splice the new plug into the factory wiring harness. Depending on the plug, may be able to even go to the factory spot inside the headlight housing to make a "like factory" connection.
I have found if you can stop by say a NAPA parts store, they tend to carry more of the electrical stuff than other stores do.
mrfizon88, if you aren't looking to switch to HIDs then the fix Thermo is describing is simple. You just need small hands to work in the headlight area. If I recall, the current bulb holder probably has two wires going to it, yellow and maybe brown. Solder a new H1 bulb holder to the yellow and a new female spade connector to the brown. There is a male spade on the side of the bulb hold down clip that you can connect the brown wire to. Done it.
PS some dealers actually have the "two wire' fix for a few bucks. Some tell you you need to replace the entire harness.
I know I know I'm sure it has been answered but only.partially to me I have not found an answer I'm pleased with. I'm sorry to everyone who.is getting annoyed with this question . My headlight melted into the socket and of course the dealer wants.to sell you everything that has to do with a headlight when you tell them the issue. So I wanted to ask the very knowledgeable forums opinion. My plan was to take this harness H1 Wire Hanress|H1 Light Bulb Socket Connector|KYO Plug-N-Play Heavy Duty Wire Harness Upgrade Kit and cut the back off and hardwire it into the original socket after cutting the melted socket off. Follow that by soldering and heatshrinking the wire to look proffessional. Any opioms any one?
Cheers,
mohrd (12-01-2011)
mohrd (12-01-2011)
It's good to see that JAg has finally gotten around to this. I remember my dealer wanted to replace the whole light assembly! Crazy. Hence my upgrades to HIDS, which I would still recommend.
Thank you everyone for all the help. I was able to.find the connector at auto zone and all I have to do is hardwire it tomorrow. Jaguar is still trying to get away with whole assembly garbage don't fall for it. Everyone recommends hid. I want to put them in my car but once I hardwire this new connector in will the hids still be safe for plug and play? If not and I hardwire them anyone have some pointers or even instruction? Haha and the hid I want 6000k hyper white what is a good site to get them from for a good price where they don't warm up or change colors or a good named brand.
Thanks everybody but now I have to revisit this. I went to go put the new socket in and i saw the ground wired was attached to the old one. If I cut the ground wire off where could i get the connection to attach it to the back of the headlamp. The other side has the ground wire attached to the back of the headlamp wonder if the other side should do the same
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
![Icon Snowman](https://www.jaguarforums.com/forum/images/smilies/icon_snowman.gif)
Resistance=heat and the plug socket starts to melt. It can be in this melty condition for a long time and is usually not discovered until the bulb burns out and the person changing the bulb finds that they are unable to separate the bulb from the connector.
Jaguar redesigned the connector so that only the positive wire connects to the bulb itself, and the ground wire is removed from the connector and gets a separate spade-plug connection to a previously unused grounding tab adjacent to the bulb.
skip9704 (12-14-2011)
It's gonna be a lonely Christmas.................. The Orioles 1954
Good luck!
harvey_birdman (01-18-2013)
