midgrad fuel!!!
midgrad fuel!!!
I got off of work late around 10 and decided to fill up the gas tank where i usally fill up at a cooperate cardlock gas station. Everything was normal and all of a sudden i hear a guy screaming the "F**k". I kept on pumping and he ran towards me from his Audi A6 yellen "STOP STOP" n i asked him wuts wrong, n he tells me that the premium gas was not really priemum but midgrade he read the piece of paper which was taped onto the gas bar thing. i stoped pumping and went to the nearest 7 11 and bought a STP octane boster n poped it in hoping that atleast the octane level would go up a couple of points....now my question is will the midgrade fuel have any effect on the cat?
Slower....eh maybe at WOT you might lose a few ponies, but won't be noticeable. There are so many different mixes of fuel at every grade, the ECU is smart enough to compensate. I would continue to run premium as the manufacturer requires, but a slip up here and there will have no consequences.
If the engine alters its timing for knock suppression when you put in low octane then I would have guessed that it is running at sub-optimal efficiency and therefore fuel efficiency might be reduced so it could be a false economy.
On a related note, I read on the Wikipedia page on octane ratings that
...Consumers may note that "gasohol", or 90% gasoline with 10% ethanol gives a higher octane rating (knock suppression)...
I always thought gasohol was the cheap nasty option.
I only fill with Mobil in my cars. I have no clue how their gas is formulated, but my car is MUCH quicker and has a better throttle response when I use Mobil than if I fill with BP or Shell. I can immediately tell if Mobil gas is in the tank after getting into either car even if I haven't driven it in weeks. That's how big the difference is. I believe BP and Shell use more ethanol in their gas than Mobil. Maybe that has something to do with it?
And filling with BP, Shell, etc. all make the car feel the same way. Mobil is the only one that stands out from the group.
Where i live we dont have Mobil and the only shell station that i know of looks like a run down truckers stop. However we have Petro Canada wich does the trick. on a side note i just lost a race to a friggan dodge calibir but dunt care cuz i kno he had NOS and a turbo in it.
The X-Type has above average traction thanks to its weight and its AWD system, so you need to use it to your advantage. Can you describe how you race? I have a 3.0 so it's a bit more powerful than yours, but it's still not a powerhouse on the highway at 60mph+. However it's got a very good 0-60mph time, especially with manual transmission. I just don't see how a cheap Jap/Korean car would beat you from red light to red light, unless that car was heavily modified. But then if you invest a lot of $ into your cheap car, it's not exactly a cheap car anymore.
The car does hook up, that's no doubt. I find however the top end more satisfying than the low end, and feel the car shows its legs better on the highway at higher speed. Of course I am strapped with the 2.5 auto and it is much less punchy than the 3.0's I have driven. I noticed the throttle tip-in is a little more aggresive on the 3.0 as well.
It's just not a race car. Nor are the others mentioned in the post above.
I'm not into street racing. But say 3 lanes merge to 2 ahead. And either im trying to pass someone and merge in front of them or I'm trying to get ahead so they are forced to merge behind me. That's where most of my encounters occur. Light turns green and I just mash the throttle. Thanks to the awd, I have 0 wheel slip even in rain, which is where i can easily take off ahead of people because they can't accelerate as hard with FWD or RWD. But in dry, I've been beaten by the current generation Nissan Altima I4 2.5 several times. And several other cars with I4's. The new ones have almost as much power as the X and weight less. So they are quite quick. But none of the 4-cylinders have an engine that sounds as good as the lowly 2.5. Leave your car in park or neutral and just slowly rev your car to redline (Think of hearing a car on a dyno). Do it very slowly and you will hear the pitch of the engine change tones several times. It sounds amazing.
I once raced my friend from a light till 70mph. He has an 06 sentra 1.8. We each had 2 other passengers in our cars who weighed roughly the same. And we were dead even till about 60 where I started to pull away slowly. I was only half car length ahead at 70. So the x-type 2.5 is slowwwww. The 3.0 is much better.
Unfortunately when I bought this car new in fall of 2002, they weren't giving discounts. So the 3.0 was quite a bit more expensive. They didn't start giving away the cars till 2004. Which is when everyone started just getting the 3.0s.
