Misfire - Cruise not available - Vacuum leaks - Lean Bank 1 and 2
Too all:
Is there anything else I should check, if these don't resolve my issues of the following problems:
Misfire Cylinder #, # place your number here - "Cruise Not Available"
Engine Lean Bank 1 - "Cruise Not Available"
Engine Lean Bank 2 - "Cruise Not Available"
Engine Lean Bank 1 and Engine Lean Bank 2 - "Cruise Not Available"
I've changed out the following:
1 – PCV hose - OK here, I have the ribbed one installed
2 - Checked over the rubber boot from the air filter box to the throttle body for any holes or cracks.
3 – Checked for any Vacuum leaks
4 – Replaced the Intake gaskets and the ones below the fuel rail. 12 total.
5 – Replaced the IMT Valve gaskets
6 – Replaced the PCV
7 – Removed the throttle body and give it a through cleaning.
8 – Replaced MAF Sensor
9 – MAP Sensor - Next on the list, if the problem comes back.
I've also had a bad battery that caused me some heartburn, too.
Any input is appreciated.
Jeeves12
Jeeves12
tdc
08-15-2016 01:56 PM
