Misfire issue
I could use some help. 2004 x type, 2.5 manual. I'm having a misfire on cylinder 6. I have changed all plugs and coils, new upper and lower gaskets, fuel injectors, IMT o rings, has ribbed pcv hose, compression tested the cylinder, I'm out of ideas. I read somewhere that you stand behind the engine and 1, 3, 5 are on the right, 2, 4, 6 are near the radiator...is that correct? Any ideas? Any help would be appreciated.
