Misterious sound
I assume the noise occurs, when the car is moving?
So your Jag is a manual Jag - just in case that gives someone else an idea.
It is especially difficult to guess the source of the noise, because you are recording the muffled noise from inside the car, while the noise is somewhere outside. It would already help, if you open the door, while recording.
I found this noise intriguing and I just investigated a while. And my pure GUESS is that it could be the stabilizer, see in the attached video from time-code 6:58
https://www.youtube.com/watch?v=rZGpjvjaoJA
I watched the video you posted and actually the sound looks very similar.
I will try to make a second video trying to record the noise from the outside.
I had terror could was the wheel
