modified Xtypes only
#81
It's ok but he's got way more money than me so I've got to try and keep up. He's already an Arden bodykit and twin exit Arden exhausts ahead of me. He's got a 2003 2.5 AWD with 15K on the clocks, immaculate condition. Got it for £2,500, the woman had been made reduntant and needed quick money, Jammy b*stard! LOL
#83
Meemo, I am interested in more info on the 2009 X Type lower chrome grille insert you installed. Is this a simple change out or do you havt to modify the existing space in any way? I have a 2005 and think that might look nice with the chrome fins in the upper grille. I assume you got it at the dealer since you said you work there but do you know the retail cost or another source that would be cheaper? Thanks.
#84
hes more of a caddy fan, but when he got his 89cady fleetwood, it only had 200 hp, froma v8 and was a complete pos, its always broke down, or was leaking. So he refused to buy another luxury car, and just stuck with gm's normal line up, me however, am the opposite, i will fight tot he death with any probelm with me car lol. My dads pretty loaded, but i gotta save for the stuff i put into the car, he DOES not like me toying with it AT ALLL, or dumping money on to it.
#87
#88
I gotta say exexpat, I love everything about your car, except for the new side piece. But, only because they dont appear to be color matched exactly, and because they don't hug the body well enough. There appears to be a gap by the wheel arches on the front side. But the wheels, the side markers, the grill, the front valance, the reverse lights, everything else is great!
#89
#90
if every thing goes the way i plan u will see my car with all the new mod's after one week from now ,
i luved except's side piece , i was planing to do it long time ago but after he did it i'm going with the chrome ones from the XK also cuz they got signal lights on them
but really good job except
i luv everu thing u did to ur car
![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
#91
Can I have more details about your wheel fitment please? They are what 20x8 with a 215? tire. The sidewall looks completely stretched, and the entire wheel lip is poking out. But it looks freaking awesome. How does it ride? Are you paranoid of hitting a pothole?
George
George
#92
George
George
#94
exexpat - please forgive if you have already covered this elsewhere - but I noticed the Brembo logo on the calipers. Did you install aftermarket Brembo calipers, or did you snag a set from an STR and modified to fit? Would you mind sharing your source (even by PM) if you did find some aftermarket? How's the performance?
They look very nice, btw. The rims look nice too, wouldn't last long around here (roads are garbage) but that's not your problem. You have a unique X, which is why most of us drive them anyway.
I see the watchful eyes of your purple octopus kite enjoy the view too.
#97
You could do it with a 10" wheel if you plan on 235 up front on 8.5. They won't be perfectly matched OD, but damn close. AWD usually can live with around 1% variance and traction control sensoring will let you know if it doesn't like the OD variance before you damage your drivetrain.
#99
Hey MeeMo, cool thread you started. I was noticing your high flow air filter under the hood, the cone shape looks like it pulls in a lot of air. Have you seen performance gains from this? ...........It looks like it's pulling hot air from the engine compartment.
I modified my air box recently and added a third cold air pick up. I have noticed a little more pull when I accelerate, low rpms, hi rpms, pretty much across the board. Seems like the engine was a little starved for air before, notwithstanding the two stock cold air tubes. notwithstanding ????
Here is a pic of the bottom half of the air box with my tube added.![Name: 1024102139.jpg
Size: 34.8 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/175945d1501295216-modified-xtypes-only-1024102139.jpg)
Below you can see the new hose at the left. Inside diameter = 2" or 5cm.
![Name: 1025101331.jpg
Size: 64.5 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/175946d1501295216-modified-xtypes-only-1025101331.jpg)
Total cost: $20 + your time. I did this one at my desk at home with a hole saw bit, a drill, and a tube of clear silicon adhesive. Of course I also had to find the right piece of hose, I think it a radiator hose for a bigger engine.
I took care to seal the air box with the silicon so it would not pull in hot air from the engine compartment. Anyway, my engine is a little more assertive...Dig IT!
#100
my 2006 Sport:
H&R springs,
bilstein comfort struts,
new upper strut mounts,
cross drilled/slotted disc-italia rotors
akebono ceramic pads,
black painted calipers
Denso Iridium plugs
intake resonator-delete
exhaust resonator-delete
throttle-body coolant bypass-mod
K&N air filter
gutted trunk to reduce weight
stock alpine upgrade stereo
19" wheels with all-season tires
black smoked side-markers
blacked-out front bumper markers
my 2002 sport: http://www.cardomain.com/ride/225379...s-moines-ia-us
H&R springs,
Denso Iridium plugs
K&N air filter
