This months parts
This months parts
Was just wondering how much you guys have spent on your x type this month so far i have brought so far.
X2 universel c.v boots @ £20.55
Brembo brake covers @ £9.40
X6 litre's castrol magnatec 5w 30 @ £35.97
Genuine jaguar power steering additive @ @ £10.00
Front Black drilled and grooved brake discs @ £49.99
K&N oil filter @ £8.99
spark plugs @ £12.50
X2 Rear lower control arms @ £55.00
Not a bad list but i will be happy when i can enjoy this car with out having to worrie about it all the time.
If any one would like links to any of the part just ask.
Hello Fixit,
Your list appears quite reasonable for a 2001 with typical milage.
How many miles/Km?
I've a similar list over the past two years. Several oil changes. Replaced warped front brake rotors. Had a cracked weld on a trailing arm re-welded.
All said, not much maintenance for a 2004 with over 120,000 miles.
best regards,
Bill
How many miles/Km?
best regards,
Bill
GENUINE JAGUAR X-TYPE POWER STEERING ADDITIVE | eBay
Its used to quite down noisey power steering pumps.
GGG (11-16-2012)
I dont think im going to be using the car next week lol £202.40 may not be alot to most people but as im waiting to start a new job i feel it when i have to spend on the car.
Hello Fixit,
How many miles/Km?
best regards,
Bill
How many miles/Km?
best regards,
Bill
TSB JTB00055 - Power Steering Squeaking
There's a TSB on rectifying Power Steering Squeak:
TSB JTB00055 - Power Steering Squeaking Repair Procedure.pdf
Apparently the noise is due to the pinion seal in the power steering running dry and the sound is transmitted up the column and into the cabin.
The TSB suggest it's a temporary solution and not a permanent fix.
fix it (11-16-2012)
Wolfy
05-28-2024 08:06 AM
99xk8guy
06-05-2023 06:28 AM
