More issues and a dangerous concern
So we all knew how my car bit the dust with a transmission. Which i replaced for 4500....more problems. Pulling allot to the left i can change a line with out touching the sterring whel with in a few meters.
Problem the continental toruing tires. Apparently according the the shops in town they have a tendency to spilt cuasing vibrations and a very very dangerous situation.
Thought id let everyone know
Then one day for no apparent reason, the belt decided to come out of the side of it, basically destroying the tire....
Be careful with those things.
George
I haven't done a think to my X-Type except for aftermarket stereo. It's my winter / bad weather beater.
George
Sorry, dunno how I reposted that...
I've had two different continental tires fail due to belt shifts. Both in the same size, but interestingly enough NOT on the same car. The X-Type, and a Mecedes C-Class. The X-Type was the only one where the belt came out of the sidewall though. I used to have a picture of it somewhere.
Needless to say I will NOT be buying a Continental tire again.
George
George
If that was an internal failure of the tires with the belt seperating wouldn't they replace the tire or at least pro rate a portion of it? That seesm like a manufacturing defect.
Now that you have new tires is it driving properly again or is the severe pulling still there?
I think I have the same issue with one of my front tires. Looks like the belt has shifted and I am getting a lot of vibration in the steering wheel. I can see the belt a little now on the outer edge of the tire, but there is still a lot of tread left there. Ill be chaning them out this weekend, but won't drive on them until then thanks to the advice posted above. Could have been a bad situation.
DO NOT DRIVE ON THEM AT ALL
This can be very dangerous and even fatal. Once the belt is gone....its out of control for the car. It very important you have it looked after.
And you all welcome, just trying to help my fellow or former jag owners from expensive problems and body work downt he road.
It was shocking to see the tire fail like that.
George
Received 2,263 Likes
George
