MPG seems really low. What do you think???
Prior to my engine swap i believe i was gettin around 300 miles out of a tank and thats when the light comes on. I know its a 16 gal tank but when light hitrs you are at 14 so how do you guys rate your fuel?!
Since the newer engine im seein like 260 miles to the tank and i drive 33 miles one way to work. 31 miles being highway. I do not dog my car but im not starin at the MPH either. Even if i did 260 divided by 16...thats 16.25!!!!????? WTF?
I recently did fuel filter, air filter, and plugs. Anybody else experiencing crappy milage? What are you guys getting?
My X is a 3.0 Auto by the way.
Now that I've switched to 4 dedicated winter tread tires,my mileage has dropped a couple MPGs to around 22-23. With the summer tires, it normally got 25-26.
That's also with a 40 mile commute (one way) - 30 of which are freeway.
I also keep my tires inflated a bit over (3-4 PSI) the recommended pressure as it tends to wear the outer edges when I go with the recommended pressure. This way they wear evenly and it probably does improve the mileage a tad.
I don't really drive highway miles too much because my school is in town, but I get around 19.3 MPG according to my computer system in the car. But lately I've been having some fun with the car and have dropped to 18.5 MPG Also, is the computer system on our cars accurate cause I have literally watched the "Miles Left to drive" counter go down in no time.
X-types get rather 'poor' gas mileage. I would say 16-17mpg. I drive like an imbecile any time traffic is light or others aren't around and I can watch the needle dive.
Even with the 3.0 we have an inimical power-to-weight ratio.
We all know that AWD cars in general already possess poor gas mileage due to the nature of the drivetrain and corpulence, but add to that luxury-interior amenities such as sound- dampening, thicker glass, moonroof assembly and a 50lbs battery! (I use a 23lbs battery in mine because I find that ridiculous)
I also find drag coefficient to be high on the X-Type. The fine gap between the headlight assemblies is one overlooked space I feel creates drag on the highway. I used to zip-tie it down TIGHT when road racing my prior X-Type. Also, my Lexus SC430 has a heavily modified V8, and the computer claims 18mpg, and I fill it up much less than the X-Type!
Thanks for your responses guys. Man some of you are gettin 22+??!!! Jealous!!! LOL
Well honestly prior to the swap i wasnt really impressed with the milage. I know it wouldnt be great due to a lot of weight and AWD but man. I guess i am pretty free spirited with the car cuz as you guys know its just fun to drive. I guess im much like you J-Bond...any open road and im lettin this cat pounce! Ive been drivin modded mustangs since i was 16 and varius other Sport related drivers. My overall crush and long lost love was my 04 Lightning F-150 and my X is comparible to that as far as gas milage and using PREMIUM.
When researching the Lincoln LS engine, it did however state it had slightly more HP and TQ and a few more MPG. Im not sure whats goin on but im confident my spirited driving would bring it down to the 16's mpg. On a tank of gas i maybe jump on it 8-10 times where i pull the gears to anywhere in the ball park of 90-115. If your wondering, here in Michigan on I94 between 10 mile and Metro Airport its pretty much every man for himself. LOL. I dont know guys, ill have to do a fair test when i go up north or a steady long trip i guess.
I was reading an article that is has more to do with the colder denser air, and the car having to burn more fuel to keep proper fuel/air ratio. The car can compensate slightly..... but why, winter driving with another 10-15hp is way more fun
Also consider the fluids are colder, so it take more to run the engine, and the AWD system.
Location: That Rectangular Hole in the Consciousness of America
Earlier this year, in the heat of summer, I made a run of about 700 miles with our 2002 2.5 AWD and averaged 24.56 miles-per-gallon, driving like the elderly have intercourse (easy, easy, easy).
Last week I did a similar run through snow and ice, strong winds and a snowstorm with an average of 24.64 miles-per-gallon! Temps averaged -8f (-22c) and I drove the car like I had just stolen it.
The difference in mileage was hardly enough to qualify as being a difference.
Possibly the extra speed I drove at actually increased the mileage? (it was considerable - I put the studded tires and AWD through its paces and was truly awed with the performance of both).
The three constants that changed were:
1) 5w20 oil now vs 10w20 oil then,
2) "Real", non-catalytic-cracked gasoline from Wyoming on the return trip, and
3) the Oil Level was NOT 1/2 quart high this run.
All things being equal, it appears the oil level had as much to do with the mileage as anything.
If you are getting lousy milage, I would suspect a slight over-filling of the the crankcase oil. I have read here in a couple of threads on this forum that it can have a considerable negative effect on mileage, and I believe I might have proved it out.
I must say, a lot of you are getting an average on gas mileage. I have had my cat for a year now, and it's my first one. I have an 02, 2.5. Which, is a little different from the 3.0, but I would think the mileage should be pretty close. I was getting what you guys are getting before I started putting in a fuel cleaner and booster. I was getting anywhere from 19 to 21 around town, and 23 to 25 on the highway. Now I live in the mountains of Pa. too. But once I started putting in the STP cleaner/booster the best mileage on the highway I get now has been 34 MPG and around town 22 to 25 MPG, depending if I'm going up a lot of hills. All of this I'm going by what the car computer is telling me, and it seems right on the money, I get 100 miles out of a quarter tank of gas. Try putting in some cleaner, maybe the injectors from the new motor are a little dirty, a little cleanning can't hurt and maybe it will help your mileage.
I haven't calculated my fuel economy lately, but I generally get about 400 miles out of a tank sometimes more, sometimes less.
I think the manual trans probably helps some, and I generally don't drive like a maniac, at least not in the X.
What tire pressures are you guys running? That can make a huge difference. I've got mine at about 34 PSI to help fuel economy.
Still averaging above 25mpg in our X type in 95% city driving (3 mile round trips during rush hour). I hardly call that poor, at least when I compare it to the XJR which is getting 11.5-13mpg is my 3 mile round trip commute long before traffic gets bad or the solid 11mpg the TVR offers. Gives me plenty of reasons to take the bike and savor in my 65-80mpgs
Wow some of you are killin me with your mpg!! LOL. As high as 400 miles on a tank??!! Congrats!!!
J-Bond...my cat does seem a little faster actually. lol. And yes in deed Ford does lower their stats sometimes and i also can atest to this. A good friend of mine owns and operates Alternative Auto Performance in Chesterfield, MI. He used to tune all my mustangs and is a great guy. The 03-04 Mustang Cobra, the 4.6 supercharged stated it had 390 hp when it came out. On the dyno i have never seen one hit such low numbers!!! Those terminators were pushing 430-445 to the wheels!!!! With a simple pulley change and exhaust they were creepin up on 500!! Some say its for insurance perposes and what not but hey, do what ya gotta do Ford
As far as some of the guesses, i would say the guys with the 2.5 manual should be pushin the numbers provided. Us guys with the 3.0 auto's, i dont know man, i wish i could hit those numbers. One of you stated no real change between babying and drivin like ya stole it does have something to do with rpm's and more efficient fuel burn. Like the old 5.0 mustangs, you put a 3.73 gear in over the 2.73 and you actually get the same mpg and sometimes more due to the rpm range and the efficiency. Cold weather does provide more dense air and would probably call for more fuel and the few other guesses but man, im gettin like 10-15 mpg less than some of you, maybe more. Just odd. Ill throw some fuel cleaner in and due my early oil change from the engine swap so i some of the BS out and see what happens.
