mr mojo
Welcome to the forums. You have come to the right place. This is most likley caused by a vacuum leak and that is putting the car into limp mode. The three most common areas to look at are the IMT O-rings, the brake booster check valve and the PCV hose. There is a ton of information on here about that. Do some searching on here for that code and you will find all the info you need. Those issues are very simple, easy and cheap to address. Good luck.
