my retrofit touchscreen vs my doubledin,lots of info
well i first installed a doubledin, which was cool it had all the bells and whistle
but then someone tried to break in and take it ,they had no such luck everthing is bolted down,
so now i thought let me try the stock touchsreen sat nav and add movie play back,and a backup camera, usb ETC,
so my first task was to locate all the parts and shematics heres some pic of what i had to get
i posted some of my past projects also
i hope i dont blind you guys with all these pics
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54619-my-retrofit-touchscreen-vs-my-doubledin-lots-info-20130819_141738_zps488d6485.jpg?dateline=1379206854)
what you see is the touch sreen,
harness ,
remote climate controll unit,
dvd rom drive,
gps antenna
optical link
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54620-my-retrofit-touchscreen-vs-my-doubledin-lots-info-20130713_121118_zpse5cdff69.jpg?dateline=1379206854)
the piece above is the remote climate controll unit the hardest part to get,i got lucky i have 2
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54621-my-retrofit-touchscreen-vs-my-doubledin-lots-info-20130713_121429_zps2ff149ee.jpg?dateline=1379206854)
it fit perfect in the side
heres some pics of install
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54622-my-retrofit-touchscreen-vs-my-doubledin-lots-info-20130914_183608_zps600b73ca.jpg?dateline=1379206854)
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54623-my-retrofit-touchscreen-vs-my-doubledin-lots-info-20130914_180107_zps389c8725.jpg?dateline=1379206854)
started wiring things up
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54624-my-retrofit-touchscreen-vs-my-doubledin-lots-info-20130914_180418_zpse2813ef1.jpg?dateline=1379206854)
backup camera at night
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54654-my-retrofit-touchscreen-vs-my-doubledin-lots-info-20130913_211422_zpsa36ab63e.jpg?dateline=1379213041)
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54625-my-retrofit-touchscreen-vs-my-doubledin-lots-info-20130913_174921_zps15043354.jpg?dateline=1379206854)
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54626-my-retrofit-touchscreen-vs-my-doubledin-lots-info-20130914_164129_zps22cc3ae0.jpg?dateline=1379206854)
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54627-my-retrofit-touchscreen-vs-my-doubledin-lots-info-20130914_164222_zpsa0ce9e32.jpg?dateline=1379206854)
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54628-my-retrofit-touchscreen-vs-my-doubledin-lots-info-20130909_193336_zps132ebd38.jpg?dateline=1379206854)
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54629-my-retrofit-touchscreen-vs-my-doubledin-lots-info-20130909_185444_zps52a3b1cd.jpg?dateline=1379206854)
for the backup camera you tap into our rear light plug the grean and black wire
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54630-my-retrofit-touchscreen-vs-my-doubledin-lots-info-20130901_191211_zps8ec626cb.jpg?dateline=1379206854)
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54631-my-retrofit-touchscreen-vs-my-doubledin-lots-info-20130901_191133_zpse4fe0583.jpg?dateline=1379206854)
phone btooth working
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54792-my-retrofit-touchscreen-vs-my-doubledin-lots-info-20130915_184552_zps38554766.jpg?dateline=1379287012)
heres some of te plugs i orded
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54632-my-retrofit-touchscreen-vs-my-doubledin-lots-info-20130819_141842_zpsddc78f76.jpg?dateline=1379206854)
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54633-my-retrofit-touchscreen-vs-my-doubledin-lots-info-20130808_203344_zps66102c87.jpg?dateline=1379206854)
heres some of the schematics if you want to try it yourself
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54634-my-retrofit-touchscreen-vs-my-doubledin-lots-info-nav-connectors-2_zpse465fab6.jpg?dateline=1379206854)
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54635-my-retrofit-touchscreen-vs-my-doubledin-lots-info-nav-connectors-1_zps083fda2f.jpg?dateline=1379206854)
this diagram is from dave x thanks bud
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54636-my-retrofit-touchscreen-vs-my-doubledin-lots-info-x-type-harness_zpsae115f99.jpg?dateline=1379206854)
look in that mess of wires is the navtool thats what you need to play movies and backup camera of course i straightened up the wiring neatly
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54637-my-retrofit-touchscreen-vs-my-doubledin-lots-info-20130909_181215_zps0696d0f2.jpg?dateline=1379206854)
heres the button i switch between movies and navigation
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54638-my-retrofit-touchscreen-vs-my-doubledin-lots-info-20130901_135108_zps909372ca.jpg?dateline=1379206854)
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54639-my-retrofit-touchscreen-vs-my-doubledin-lots-info-20130901_135032_zps3d8d21b5.jpg?dateline=1379206854)
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54640-my-retrofit-touchscreen-vs-my-doubledin-lots-info-20130526_212010_zpsf54e9367.jpg?dateline=1379206854)
heres the audio modulator
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54641-my-retrofit-touchscreen-vs-my-doubledin-lots-info-scosheinstall012_zps859211c7.jpg?dateline=1379206854)
this was my double din install youve seen before
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54642-my-retrofit-touchscreen-vs-my-doubledin-lots-info-4455020.jpg?dateline=1379206854)
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54643-my-retrofit-touchscreen-vs-my-doubledin-lots-info-307-1.jpg?dateline=1379206854)
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54644-my-retrofit-touchscreen-vs-my-doubledin-lots-info-100_0264-1.jpg?dateline=1379206854)
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54645-my-retrofit-touchscreen-vs-my-doubledin-lots-info-015-1.jpg?dateline=1379206854)
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54646-my-retrofit-touchscreen-vs-my-doubledin-lots-info-012-3.jpg?dateline=1379206854)
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54647-my-retrofit-touchscreen-vs-my-doubledin-lots-info-0092-1.jpg?dateline=1379206854)
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54648-my-retrofit-touchscreen-vs-my-doubledin-lots-info-0082-1.jpg?dateline=1379206854)
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54649-my-retrofit-touchscreen-vs-my-doubledin-lots-info-001-5.jpg?dateline=1379206854)
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54650-my-retrofit-touchscreen-vs-my-doubledin-lots-info-deckz1-1.jpg?dateline=1379206854)
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54651-my-retrofit-touchscreen-vs-my-doubledin-lots-info-quad-pipes-b.jpg?dateline=1379206854)
WRITE UP TO ADD BACK UP CAMERA AND MOVIES TO SAT NAV
PARTS NEEDED
NAVTOOL i paid $150 on ebay
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/55610-my-retrofit-touchscreen-vs-my-doubledin-lots-info-rgbuni_box_zps46d1e894.jpg?dateline=1379819819)
BACKUP CAMERA i paid $12 ebay
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/55611-my-retrofit-touchscreen-vs-my-doubledin-lots-info-camera_zps4a07ad0b.jpg?dateline=1379819819)
DVD PLAYER i paid $79 for a soundstream one ,i changed the boss one i had
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/55612-my-retrofit-touchscreen-vs-my-doubledin-lots-info-soundstream_zps5f68b13c.jpg?dateline=1379819819)
in the diagram all you have to do is cut the four wires in the diagram
on the navtool theres also a acc wire to be hooked up and the backup camera
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/55613-my-retrofit-touchscreen-vs-my-doubledin-lots-info-pugcolors_zps0b799945.jpg?dateline=1379819819)
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/55614-my-retrofit-touchscreen-vs-my-doubledin-lots-info-shopwirejpg_zps85bf7b81.jpg?dateline=1379819819)
i made these diagrams to help you guys out when you get the navtool you will see all the wires matchup to my diagram
the diagram they give you is no good , i figured it out for you guys
heres the bluetooth and voice modules connected
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/79311-my-retrofit-touchscreen-vs-my-doubledin-lots-info-20140320_193901_zpst1l3hehh.jpg?dateline=1396801309)
heres the harness
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/79312-my-retrofit-touchscreen-vs-my-doubledin-lots-info-20140320_193946_zps03hnl0br.jpg?dateline=1396801309)
running the bluetooth module under the carpet
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/79313-my-retrofit-touchscreen-vs-my-doubledin-lots-info-20140402_172628_zpsugsekaqv.jpg?dateline=1396801309)
putting the harness under the carpet is a bitch
PLUS I FOUND SOME M&MS under the console lol
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/79314-my-retrofit-touchscreen-vs-my-doubledin-lots-info-20140405_132047_zpsix6ppmv9.jpg?dateline=1396801309)
this is what you need for bluetooth and voice intergration
harness ,
dvd rom drive,
gps antenna
optical link
PARTS NEEDED
heres the harness
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/79315-my-retrofit-touchscreen-vs-my-doubledin-lots-info-20140320_194232_zpsqz1op3qf.jpg?dateline=1396801309)
The following 8 users liked this post by dennis black:
Brit57 (03-21-2017),
Bruce in North Dakota (04-12-2015),
CWMcGonigal (03-31-2015),
jackra_1 (12-28-2014),
JJCxtype (10-26-2013),
and 3 others liked this post.
HERE are some past projects
my rear wheals had bad camber ,so i put a volvo control are ,a tip from thermo thanks
now my wheels are straight
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54713-my-retrofit-touchscreen-vs-my-doubledin-lots-info-20130527_121707_zpsebaa295c.jpg?dateline=1379265307)
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54714-my-retrofit-touchscreen-vs-my-doubledin-lots-info-20130527_121716_zps60d8477c.jpg?dateline=1379265307)
then i had sticking calipers i replaced them and rebuilt the old ones
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54715-my-retrofit-touchscreen-vs-my-doubledin-lots-info-20130527_121745_zpsf3e27814.jpg?dateline=1379265307)
put quad pipes
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54716-my-retrofit-touchscreen-vs-my-doubledin-lots-info-20130527_122606_zpsf783b69a.jpg?dateline=1379265307)
did the boot plinth mod thanks to one of the members idea
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54717-my-retrofit-touchscreen-vs-my-doubledin-lots-info-20130526_211910_zps8e674f49.jpg?dateline=1379265307)
grille mod
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54718-my-retrofit-touchscreen-vs-my-doubledin-lots-info-100_0091-1.jpg?dateline=1379265307)
lowering springs
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54719-my-retrofit-touchscreen-vs-my-doubledin-lots-info-100_0186-1.jpg?dateline=1379265307)
put quad pipes
grille mod
lowering springs
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54720-my-retrofit-touchscreen-vs-my-doubledin-lots-info-100_0384.jpg?dateline=1379265307)
The following 4 users liked this post by dennis black:
i was trying to find a good player but there was not much to offer i put it in to see if it would work,and bam it worked , and i no what you mean about boss equipment there cheap and like jvc crappy ,so i put it in the trunk and wired it wireless so no one would no lol
now dont tell anyone i have a boss player,
but it gets the job done till i find a quality one,
this is the one going in,now everything works
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/54785-my-retrofit-touchscreen-vs-my-doubledin-lots-info-blaupunkpt_zpsecd4b433.jpg?dateline=1379284317)
Stuart Beattie (04-07-2014)
I hear ya on that
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/68485-my-retrofit-touchscreen-vs-my-doubledin-lots-info-20140112_150606_zpsb1c8baa9.jpg?dateline=1389568821)
to get the daimler log first hold the menu and phone buttons together dont let go untill you see this screen
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/68486-my-retrofit-touchscreen-vs-my-doubledin-lots-info-20140112_150156_zpsa3afb336.jpg?dateline=1389568821)
punch in the code 1971
then you will see this screen
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/68487-my-retrofit-touchscreen-vs-my-doubledin-lots-info-20140112_150217_zps60096241.jpg?dateline=1389568821)
then hit the misc button
you will see this
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/68488-my-retrofit-touchscreen-vs-my-doubledin-lots-info-20140112_150358_zpsa7d41664.jpg?dateline=1389568821)
now hit sytem options ,you will see this
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/68489-my-retrofit-touchscreen-vs-my-doubledin-lots-info-20140112_150452_zpsc8be6952.jpg?dateline=1389568821)
now hit the daimler button then go back
to logo screen
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/68490-my-retrofit-touchscreen-vs-my-doubledin-lots-info-20140112_150539_zps4a42e16d.jpg?dateline=1389568821)
thats it
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/59911-my-retrofit-touchscreen-vs-my-doubledin-lots-info-20130727_200831_zpsb00d6a02.jpg?dateline=1382751420)
beware never hit system update or any update you will have a black screen
i hope that helps skinny
The following 2 users liked this post by dennis black:
luvdaqtr (02-02-2015),
