My very first 2002 xtype Jag
HI all, I just on to this forum and all the popel sound great.
I just picked up my 2002 x-type and have been doing some research and I am quite nervous to say the leaset, Edmunds web site did not have to many nice things to say about the 2002 Jag, many issues and parts problem...I dont want ot be discouraged and usually the forum folk now best lol. I have to say my jag is standard and it is quick in 2nd and 3rd and 4th really fun,exciting..and I kinda of love it...do I need deep pockets...please give me your feedback...I really want to keep the all wheel drive monster :-)
I think the general feeling around here is that Edmunds can just stick it! Except that we have them partly to thank for the fact that we can pick up such great little cars for not so much money. The X is based on a very successful and well-regarded Ford car, and Jag put a stunning body and interior on it. True, the transfer case would seem to be a bit of a trouble spot, but a whole bunch of dedicated owners and tinkerers have found procedures and preventative maintenance to pretty well put that one to rest. It's a very complex car; rewarding, but complex. It rarely seems to strand anyone, but little glitches can be annoying, and expensive; particularly if you have to rely on a Dealer. That's why you'll find this forum so valuable- there's not much that can happen to your car that someone here hasn't experienced, and probably fixed, before. You'd be amazed at what you can tackle knowing help and guidance is just a mouse-click away. This is my second Jag, which means I knew exactly what I was getting into, and I couldn't be happier. If we posted every time we came back from a drive with a big, fat grin on our faces there wouldn't be enough room on this forum for bitching.
Received 3,887 Likes
Glenn, first off, welcome to the forums. We do ask that you stop by the "New Member" section and give us a little bit about yourself. We are a friendly bunch around here and I think you will see we like to get to know each other. Contrary to whatever image that might be out there.
As for the car, yes, the car can be very fun to drive, but the big issue with the car is the transfer case (as you probably read about). The skinny on it can be put very simply: drive hard, deep pockets, drive sensibly, last forever. The transfer case can last a long time, but we have found through various means that the transfer case flexes a lot under heavy load. This flexing leads to the case actually cracking and then effectively splitting in half. As you can imagine, this is not good. But, normal every day driving and the occasional romping to get up to speed/pass someone is ok. But, just keep in mind that the more you do it, the shorter the transfer case life is going to be.
You may have also seen a lot of things about vacuum issues. If you know what they are, they are all easy fixes that don't cost a lot of money. Even a "less than backyard mechanic" can fix these issues. Just need a little bit of desire and a place like this.
So, take the kitty out, don't be afraid to let the kitty stretch, but be smart about what you are doing. I think you will find the car to be very capable (especially in the snow) and meet all of your needs. The only true "downside" that I can put on the car is the lack of aftermarket stuff for the car. In some ways this is good (transfer case), but on the other hand, it would be nice to have some options without having to go custom.
Thanks everyone..I will be sure to chekc out the new memeber FAQ's as well thanks for th skinny on what the kitty can and shouldnt be doing..I just got it so I have lets just say been stretching her legs a little in second and third girl...wow can she move..a few questions concerns
1-will I know before the transfer case goes
2-can I do anyting to prevent or is it like a starter when she goes she goes
3-he mentined preventive maintance..besides oil changes what else?
4-seems the trims are quite weakeness...going to get some glue to glue all back together lol
5-everytime I play with her I am going to be thnking of the transfer case flexing... :-) hope I dont break her..she is so much fun so far..
thanks G
thanks G
As for the transfer case going, pretty much once you start hearing noises that are directly attributed to the transfer case, she is pretty much done. Once you start hearing the clunking and squealing of the transfer case, you don't have much longer before all hell breaks loose. As for prevention, you can do periodic gear lube changes to help prevent loss of lube failures, but beyond that, the gas pedal is about the only other preventive thing that you can do.
As for preventive maintenance, treat it like any other car. So, rotate tires, differential lube changes, shocks, brakes, etc. Yes, I know the differentials and tranny are "sealed for life", but change the fluid. Yes, the engineers have done a lot with making fluids last longer, but the fluids are only so good.
As for the trim, someone must have pulled them off in the past. All the trim on my car has been stuck on since I got it with nothing coming loose. Normally the manufacturers make sure that the trim is stuck on good and if anything, make it a pain to pull it off.
I felt the same way when I bought my X Type. I saw lots of negative comments about the entire X Type line. And I fail to see it at all. The body design over all looks great, and inside it's nice and comfy - so much more than the American crap I've become used to over the past thirty years.
I understand that it's the "cheapest" Jaguar, but every automotive line needs an entry level car. I remember Mercedes and BMW (here in the United States) being luxury cars for the very rich. Now every teen can buy one. The X Type was the best selling Jaguar to date, and yet still is the best kept secret.
I got my X Type because I was looking for "basic four door transportation". I was looking at BMW, Audi, MB, maybe even a Lexus.... Buying the X Type was a god send. Everyone thinks my car is brand new and worth $100k. It's comical.
Like I said before, there's always a "Wow" factor whenever a Jaguar arrives.
Can't say that about BMW, Lexus, Audi, nope, not at all...
Jaguar: Grace, Pace, and Space - Sir William Lyons
I may be one of the few people who bought a new X Type. I believe in the US at least when I bought mine in 2006 there were only around 20K or so sold that year.
I've taken care of it - nothing out of the usual and it's been a great car to drive and own. I believe it is STILL one of the most attractive cars around.
I've owned entry level luxury cars for a long time. I've owned an Acura TL, BMW 325i and a Mercedes C280 4 Matic and of all the cars I've owned I've enjoyed the X Type the most. So much so that the Jaguar forum is the only one I've ever posted in (I did follow the forums for the other cars as well not never posted).
I feel it is the best combo of interior and exterior styling, comfort and a performance. The engine isn't as smooth as the BMW or Mercedes but it makes up with better acceleration and power in DC traffic conditions (at least compared to the C280 which overlapped with my X Type ownership).
Enjoy your car
Enjoy your car
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
I know this sounds funny but I cant wait to get home from work (I take the subway) and take the kitty out for a spin,drive,romp
I really truley enjoy her
i want to see how she does in the snow to see how the awd is. I have a volvo XC 70 which was awesome...
what can I say I am Jag lover now.. :-)
thanks all for the great feedback.
I will post questions when thy arive or look for some of the issues and respond to those postes..
thanks G
thanks G
The X-type will be awesomer! Run snow tires on all four corners and you will amazed. One of the reasons I opted for the '02. Truer AWD than later model years, some will say.
Dicque
09-19-2015 12:53 PM
