My X-type electrical errors
Hi Guys
I have to say I am new to this Forum. I did post this in the wrong place I apologise.
I recently bought a 2004 X-Type Sport D. It had been sitting for some six or seven months on my neighbours drive. Anyway I always wanted one so managed to acquire it.
It needed a little doing to it before going through an MOT namely new brake discs and pads new tyres ETC. Anyway that all done it sailed through the MOT and I have been very pleased with it, but now? Well I have an electrical problem which a Auto Technician couldn't work out.
Light on the dash flash on and the rev counter stops working. This happens intermittent but the car continues to drive ok. When I put a Diagnostic iCarsoft i930 I get the following
Engine Control Module
P0500 Vehicle speed sensor 'A' circuit malfunction
P1260 Security imput / theft detected Vehicle imobilised / theft detected - engine dissabled
P1637 CAN link engine control module ABS control module circuit / network malfunction
U1900 CAN communication BUS fault passive anti theft system
U2202 Invalid configuration data received.
B2141 Non - Volatile memory configuration failure
B1262 Defrost servo motor-circuit failure
B1236 Vent servo motor-circuit failure
B1239 Airflow blend door actuator - circuit failure.
What an introduction to the Jaguar X-Type.
If any one has any ideas I would love to hear them.
thanks
thanks
+1 on the battery. It is always the first step in troubleshooting a Jaguar.
First use the code reader and clear all of the codes. Then remove and charge the battery, and clean the battery posts and the cable connectors.
Reinstall the battery and start up the engine. With it idling use a digital volt meter and check the battery voltage post to post then check cable connector to cable connector. There should be very little difference if the connections are good. Then check the positive cable at the starter to ground it should read the same voltage as the cable to cable connector.
Once you are sure the cables and connections are all good take it out for a spirited drive and then recheck the codes.
The x-type is known for internal corrosion of the positive cable causing all kinds of gremlins.
The following 2 users liked this post by avern1:
DaveJessop (06-27-2017),
Willies (06-28-2017)
Hi All
Thanks for the replies to my thread. I really appreciate all the help.
Now here's the thing. I checked the battery cables and all was fine as far as I could tell following the steps above, but what about this some one said have you checked the battery in you key? Well no I said I lock and unlock the car fine. Put a new battery in it anyway so I did and guess what it has not happened since even although it was happening just before I changed it. Has anyone come up with this before or am I just clutching at straws. I suppose time will tell. We shall wait and see.
I don't know if the new key fob battery was the answer but it is now 3 days since I have had any faults. I put a brand new battery in the car when I got it so after checking out the cables from the battery which as I said were all fine I put it into a auto technician who was not able to fix it other the to say
"It could be this, it could be that. It will take hours and a lot of money to find and fix it. Is it really worth it?"
Needless to say he charged me for his time £90.
In the end it was my daughter who said that she had the very same problem with her Cleo and they said that the key fob was the cause before charging her £150 for a new one. It has been fine since. Thank goodness it only cost me a couple of quid for a new battery for my key fob and as I said that's three days with no problems. It may not have been the cause as Alphadude said but it is looking more and more like it was the cause.
So there is another possible fix for the forum. I will keep my eye on it and if it comes back I will let you all know.
Thank All!
Thank All!
