my X-type is over heating
![Post](https://www.jaguarforums.com/forum/images/icons/icon1.gif)
Any suggestions? I tired switching to water, and that didn't work. I will say I see some air bubbles that raise in the tank, but I don't see leaks when I place more liquid in the tank (when it over heats coolant or water level decrease). also my battery just died. Could a weak battery play a part?
in the front of the engine next to the CAT below the water pump its in a black plastic line , its easy to remove from the bottom.
if its not that then its the Heads............good luck!
Head Gasket HEADS: do you notice the water/anti level dropping ?? Water in your oil?? lift your oil fill cap and look under it, do you see sluggish substance ??? these heads warp very easy due to there cheap made head bolts that stretch a little to much then it has to under heat.
Thank you for your replys. Shortly after me last post, I randomly stop by Autozone to buy more coolant and the guy there suggested that I check the thermostat. I went back home and found out where it was located, and found out that you can just remove it until I can buy another one. As mentioned in the article, the works fine and its alot cooler. I just have to make sure I replace it before the weather get cooler, because the car will have a hard time warming up.
No you can't just remove the thermostat. The t-stat actually slows the passage of fluid through the system which helps it to absorb more heat. By removing it your sensor might be reading a lower temp but you actually might have a hotter engine. Until you replace it I wouldn't be driving the car. That is unless you need to make a boat payment for your mechanic!
![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
I took out the t-stat, until I the replacement come in the mail, and that seemed to fix the problem until I can put the new one in. But now the cooling fan is not kicking on. I've tried turning on the AC to "low" for 5 mins. to see if the fan kicks on but it doesn't now. Someone mentioned about checking the fuse, but I'm not sure which one is the correct one since I see some for the fan and others for the AC. Also how can you tell if a fan module is bad?
Your coolant is likely going through the engine too quickly to absorb the heat from the engine. You are likely doing major damage to your engine if you continue to run it without a thermostat. Don't worry about the fan at this point it is the least of your problems. Not knowing how the x type is set up but knowing how most cars are set up, your fan is controlled by a thermo switch on the radiator itself, the temp gauge is controlled by a seperate thermo switch probably on the return line. You are likely not getting the collant hot enough to turn the fan off but your engine is getting plenty hot since you're basically running it without coolant!
![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
At this point there is nothing wrong with the engine. i'm trying to figure out why the fan is not turning on, but I have a few variables. My t-stat is out the car (I'm not driving the car, and the part will be in tomorrow), I just realized that when the fan was working it drained the battery (so, I'm taking it to get recharged today), and I wondering if the fan module is bad. I;m checking all the fan and AC fuses, and so far they are all fine. I did notice when I did the AC test for the fan kicking on, the car seemed like it was trying to start the fan can the lights in the car dimmed and I could hear a click.
So, could the car not have enough juice to kick on the fan since the battery is almost drained? And is there a way to know if the fan module is bad with out replacing it?
Once I get the battery and t-stat installed, hopefully that will solved the fan issue
where do you people come from?? removing the T-stat will not damage your engine. Your fuel mixture will be thrown off but no damage will be caused.
Sorry dude that is wrong. The thermostat prevents the coolant from reaching the radiator so it has time to heat up, thus allowing the engine to heat up to operating temp...... so if you remove the thermostat the system will run free flow, allowing all of the coolant to run through the radiator all the time. It does not need to stay in the engine for a certain amount of time to pick up heat..... it is running free flow so cool water is constantly running through the engine therefore the engine will not overheat (except for in this case where the fans will not turn on).
OP- when you removed the thermostat did you replace the coolant? If you didn't this is why your car is overheating and the fans are not turning on. The temp sensor for the fans is measuring AIR which is not a good conductor of heat. So as the engine is heating up the air is not getting hot enought around the sensor so the car thinks it is still cool......
You beat me to the punch..... so basically this guys is saying: that the thermostat gives resistance to the coolant flow and this is what prevents a car from overheating............
totally miss informed !! On a fuel injected system removing the thermo throws of the fuel mixture and giving you poor gas mileage, Hard cold starts. You can run the car for miles without a thermostat.
and when you change a Radiator from a car that ran low on water, sometimes it over heats because the system has air in it and needs to be pressurized to remove air pockets.
* I have the tool if you want to borrow it? * ( needs to be hooked up to a compressor )
