Mystery solved: remote control sometimes does not work
I am reporting my experience in case someone out there has a similar problem.
I had an intermittent problem with my remote control often failing to open or lock the doors. By luck I discovered the following:
When you remove the ignition key, a spring-loaded metal flap closes the slot. But if the flap gets stuck in the open position the remote control is ineffective. A drop of oil is all it needed.
The following 3 users liked this post by Davidvdm:
RudyF6 (03-21-2017)
I had an intermittent problem with my remote control often failing to open or lock the doors. By luck I discovered the following<!--td {border: 1px solid #ccc;}br {mso-data-placement:same-cell;}-->Blackweb Universal Remote Codes:
KittyVet
05-31-2020 11:57 AM
sweatyfox
01-19-2017 01:10 PM
