NAV gets HID upgrade for heads and fogs
Received 9,008 Likes
Thanks Thermo, I'm in Northern NJ so I'm not in that area, but i should be good, just take off the front clip, splice into those wires. The only thing I've worried about is if I have to run relays if I have any problem with power draw and HID's start to flicker. I'll try and take some pictures for a DIY for fellow members
Received 3,889 Likes
Maxazor, you are good with the power for the HIDs. Your car already has a relay in the circuit for both the fog lights and the headlights (low beam only). So, adding another relay is useless. Connect up to the wires that go to the bulb and you are golden. If you consider doing this to another brand car, then adding a relay may be necessary.
jmalone, if you don't mind making a trip down to Toledo, the next time I am home, we can hook you up then. But, that is up to you.
Wes, if you are looking at converting the car over from factory halogens to HIDs, plan on spending about $1000 on used headlight assemblies. They do not come cheap. New from Jag they are like $800 each (cheapest I can find, list for like $1200 each). As for the LED lights, for mine, I made my own. I bought some 285K MCD 10MM LEDs and then modified the leads to plug into the factory mount. The only thing with doing it this way is that you have to add your own resistor into the factory wiring else the LED will explode on you (literally). The resistor needs to be a 1 watt/220 ohm resistor. But, for $25, that is enough LEDs to do like 3 cars all the way around (50 lights). But, it does require some work on your part. The ones that NAV had were plug and play and required no modification. The big thing to keep in mind with these is that they are polarity sensitive. So, you will need to plug them in, see if they work, if not, flip them 180 degrees and check again.
On a side note about the LED lights, if you are looking to match up the LED lights to your headlights, I wish you luck. MOst of the LED lights are an equivolent 7000K light source. But, that is close enough to 6000K HIDs that you won't be able to tell the difference.
as for the LED's im looking for something like this
City Lights: 6k 158 bulbs
***This are NOT FOG lights!!! Infiniti calls it city lights or park lights
![](http://i90.photobucket.com/albums/k275/dranom/LEDlights006.jpg)
![](http://i90.photobucket.com/albums/k275/dranom/LEDlights005.jpg)
These are the LED's that i have in my G35 and my uncle likes the look
here is the thread
http://g35driver.com/forums/lighting...ml#post3497850
#28
Wes, the HID kit is not that complicated to install. The whole bit about installing resistors and whatnot is because of trying to install LEDs (not HIDs) without buying manufactured LEDs for that specific purpose. The HID kits are pretty much a "cut two wires and install" process. Very simple overall. Going with the all factory setup is even easier, but then, the costs are significantly higher.
#30
#31
These are the LED's that i bought for the running lights, as Thermo said, they are a bit on the purple side but still look aight
http://cgi.ebay.com/ebaymotors/White...Q5fAccessories
you wanna search for 8 SMD 194 LED if you go with a different style bulb just make sure the diameter is less than 11 millimeters to fit through the housing.
#32
#33
Irish, yes, you can in theory do this without pulling the bumper cover. But, think about all the work that has to be done and now do it with minimal clearance. You will save tons of time by simply pulling the bumper cover. Pulling the bumper cover isn't that hard really. All you need is a T-27 Torx bit (as I recall, might be T-25), a T-10 bit, and a 10mm socket/wrench. Pulling the bumper cover will only take but about 20 minutes. It comes off pretty easy. Remove the cover on the under side of the car using the Torx bit. You will need the 10mm socket for 4 bolts on the rear side near the wheel well. Slide the plastic plate out of the way. Next remove the screws half way up on the front side of the wheel well (out at the edge) using the T-10 bit. Next, there is a 10 mm bolt on the back side of the bumper cover between the side marker light and the wheel well. Having a stubby ratchet makes this job easier. Finally, put some towels down on the ground where the bumper cover is going to lay, then remove the 4 10 mm bolts (2 on each side) near the headlight assemblies. At this point the bumper cover will be able to be pulled off. Of note, you will need to pull out on the corners of the bumper cover to release some clips on the inside of the cover. At this point, once free of the clips, lay the bumper cover on the ground and you can remove the headlight assemblies using the 10mm socket, ratchet and a short extension.
Trust me, it is really easy to remove the bumper cover. Save yourself the hassle and just plan on removing the bumper cover.
#34
Thermo, Im new to the forum and loving it already. I enjoy the comraderie with all the jag owners. I had a quick question I will be in Baltimore on a work contract due to BRAC and would like to know if you guide me in installing an aftermarket HID kit... I purchased one kit but I'm assured I I'll probably need several kits. I just found out I must have my right passenger headlight wiring redone....
#35
Simply, come on down. I live about an hour south of DC, so, it will be about a 2 hour drive for you. If you want to do some research on where you are heading, look up a town called Great Mills, MD. I live on the north east corner of town.
What all lights are you looking to do? If you are only looking at doing either the headlights or the fog lights, then a single kit is all you need. If you are planning on doing both, then you will need 2 kits.
When will you be up in the area. I do have a few weekends that I have things already planned for. That way you are not wasting your time.
rsa760041
23
09-25-2015 01:33 PM
