Nav Screen Problem
Guest
Posts: n/a
RE: Nav Screen Problem
Update:
All fixed. Turns out it was reader. I pulled the plug on the reader and the screen was still dead, so I got a screen + reader + radio off ebay for 700 (I think that was a good deal... I dunno. Dealer quote was astronomical though so much better than that.) Anyway, swaped in the new screen, nothing, swaped in the new reader, and it came right up, so I put my original screen back in and now all is good.
Even came with a new disc... only 2003, but it was newer than mine. If anybody has an iso somewhere online that is newer, Ivolunteer tohelp "test" the backup procedure (ahem.)
Thanks for the help!
#32
#33
#34
#35
Oh, that makes sense. thanks for clarifying that ibjags.
I have a 2002 x-type with navigation and sometimes, the screen is lit up properly but will not recognize when I press the screen. Therefore the screen works fine visually but can't be used as a touchscreen since it will not recognize the pressure from my finger. It only happens about 5 percent of the time but it always happens when I need the navi and can't use it? any ideas? usually it will work after I drive around for awhile.
#37
Nav Screen Blank/Black/Off
I am having problem with Nav screen on my Jaguar X-Type 2002. The Screen walk up one day blank and below i see error code c1/50/51. I don't what went wrong. I was reading the thread and someone said you can pull the module off and on. Please help. The defroast is alway on and its now very high on fuel consuption.
#39
Add me to the list. I first notice the A/C temperature LCD start cycling between 50 and 51. At this point, the actual A/C seems to stop blowing cold air and now blows warm air. Then I notice the touch screen is frozen. I can only control the radio via the steering wheel. Occasionally the screen will display "communication failure: See authorized dealership". Shutting the car down does not always reboot it. Even leaving the car alone for a couple of days. Some days I can drive for hours and it won't happen. Some days just minutes into the drive. It seems so random.
I heard from one guy that I may need to replace the battery. Is that nonsense? Or is it the touch screen? Or this Nav module posted in this thread?
#40
check out post #89 this worked for me.
https://www.jaguarforums.com/forum/x...en-5716/page5/
just download the file and burn on a DVD insert dvd in player
remove your key for 30 sec
start the engine
after 5-10 mins my screen came back
EDIT :-
Guys i have uploaded the file just unzip and burn to a DVD as a data disc at the slowest speed you can.
start the engine
EDIT :-
